  3. What is 'axlTransformObject' function's exact parameters...
  • Subscribers 163
  • Views 3082
What is 'axlTransformObject' function's exact parameters?
archive over 18 years ago
Hi, In Algroskill Docs: 11 parameters axlTransformObject( lo_dbid/o_dbid ?move l_deltaPoint ?mirror t/nil ?angle f_angle ?origin l_rotatePoint ?allOrNone t/nil) Use following function check: Only 10 parameters arglist('axlTransformObject) What is 'axlTransformObject' function's exact parameters? Thanks
Originally posted in cdnusers.org by m68673
    I think that there is a problem with the Skill wrapper for the C code in this instance.
    agrlist and sklint both return incorrect results. I believe that the documentation is accurate. It works for me.
    Originally posted in cdnusers.org by Dave Elder
    Hi Dave,
    It really worked well for you? Please try the following statement and help me to point out my fault, thanks.
    1?TextDbid is a text object or a list of text objects, following statement causes an error.
    axlTransformObject(TextDbid ?move '(0.0 0.0) ?mirror nil ?angle 0.0 ?origin '(0.0 0.0) ?allOrNone t)[i] [/i]
    E- *Error* axlTransformObject: too many arguments (at most 10 expected, 11 given)
    2?Elide the '?allOrNone t', It works well.
    axlTransformObject(TextDbid ?move '(0.0 0.0) ?mirror nil ?angle 0.0 ?origin '(0.0 0.0) )[i] [/i]
    Daniel
    Huawei
    Agreed. The allOrNone option does the damage. I've never used it. Just leave it out.
    I raised a service request (31077799) on this in December 2003. The reply I got was: "This is a C implementation of the Skill keyword syntax. It is functioning correctly. R&D don't have any plan to address this." Go figure!
    Hi Dave,
    Thanks all the time. Use it correctly, that is the question. Forget the 'allOrNone' option in the document.
    Best Regard!
    Daniel
