  3. Tune differential pair delay by Skill
  • Subscribers 163
  • Views 15434
archive over 18 years ago
Hello all, I'm looking for a possibility to tune delay of differential pair automatically by the Skill program. Any appreciative idea? Thanks, Shimon
Originally posted in cdnusers.org by shimon37
    Hello.
    Depending on what You're doing, it is difficult to controll, sometimes times is not enought, but phase tolerances and phase shifting along the clines can be an issue as well, i donnot belive You can write a skill to take that into controll.
    Rgds
    Klavs.
    Originally posted in cdnusers.org by Malmir
    Hello Klavs,
    Thanks for your response.
    I think about check and repair Skill program as follows:
    1. Checks named differential pair - constrained and routed by design engineer
    ( check and compare nets path cline segments length, immediately after
    a relevant differential pair will be routed)
    2. Repairs short net path length right after it turn to a new position cause nets
    length difference (1x, 2x, or 3x cline width - exactly like in the Allegro PCB Editor
    'Delay Tune' interactive procedure)
    So, something like these.
    Thanks again,
    Shimon
