  2. Allegro X Pulse & EDM
  3. Creating New Project from Template with Managed Layout
  • Subscribers 10
  • Views 2149
DesignTech
DesignTech over 2 years ago
In the Pulse environment, you can use an existing System Capture project as a template to create new projects. Now, a layout widget is also added to the Create New Project form, which helps you select one or more Pulse-managed layouts and include them in the new project.
In the Create New Project form, select the required layouts associated with the template project and enter a name for the board/package as appropriate under the Name column.
Click here for details on the new project creation from a template.
Team DesignTech
Cadence Design Systems
