  2. Allegro X Pulse & EDM
  3. Updating Modules in Layout with Pulse Module Manager
  • Subscribers 9
  • Views 2440
DesignTech
DesignTech over 2 years ago
The Pulse environment enables the creation and management of modules for individual blocks in a design. These managed modules can be directly consumed in the main PCB.
If a Pulse-managed module undergoes changes at the module level, the changes can be synchronized with the main PCB where this module is consumed through the Pulse Module Manager.
You can launch the Pulse Module Manager in Pulse-enabled PCB Editor using Place > Pulse Module Manager.
The Pulse Module Manager displays a list of all version-managed modules related to the active board design and the count of how many times each module is instantiated in the layout. It also displays the status of each module with respect to its schematic and Pulse version. If the module is in sync with its schematic or Pulse version, the status will appear in green.
Pulse Module Manager Import Latest
If any change to the module has been made and committed to the server, the Update Available column shows a Y with the updated module version number.
Select the module and click on Import Latest to update the module in the board.
Read the article here to know more about Pulse Module Manager.
Team DesignTech
Cadence Design Systems
