  2. Allegro X Pulse & EDM
  3. Display project pulse version in SYSCAP title block and...
  • State Suggested Answer
  • Answers 1
  • Subscribers 10
  • Views 3950
Display project pulse version in SYSCAP title block and in pcb editor.
RJ202412171240
RJ202412171240 10 months ago
I am using Allegro X 24.1; System Capture, PCB Editor and are saving both schematic project and layout in Pulse.
I want to display which pulse commit I am looking at on my schematic title block - I have been doing this in other software that has revision handling and it is very practical both during actual design work and when sharing and discussing projects to know which version are currently shown.
It seems like it should be a simple enough variable to fetch from the system with something like $PulseVersion or similar.
I have done my own workaround by creating my own custom variable called PulseVersion and then run this TCL "script":
modifyCustomVar -name "PULSEVERSION" -type "Project Defined" -value "[dict get [dict get [pulse::getVersionDetails] Attributes] displayRevision]"
It will return current pulse version like "1.0" or "4.2" or "1.33.7" depending on your current commit version.
But its a manual step that in my opinion should be automatically updated when commiting. Has anyone found a better way?
I would love to have a similar solution in pcb editor also, but have not even managed to do a manual workaround in there yet :/
Best Regards
  • CadAP
    CadAP 10 months ago in reply to RJ202412171240 +1 suggested
    RJ202412171240 Please command axlPulseGetDesignStatus to get the design version status.
  • RJ202412171240
    0 RJ202412171240 10 months ago in reply to CadAP
    Thanks, that will put me on the right track.
    I guess that I need to learn SKILL and do some script that masks out the design version and put it into a variable/property somehow if I want to be able to document the version of the board in the artwork.
