  3. Inconsistent behavior of axlDBCloak?
  • Replies 8
  • Subscribers 18
  • Views 14217
migrg
migrg over 8 years ago
Hi everyone,
I'm creating an array of vias using axlDBCloak. I realized that a number of my vias (seems like they are located in the same X coordinate) don't have a net associated. My code works as follows:
via_id=mrCreateViaPadstack() -> this function creates the padstack, this works fine all the time
axlDBCloak( 'mrCreateAllViasCloak(via_id))
procedure( mrCreateAllViasCloak(via_id)
axlDBCreateVia(via_id, -1497.7:10647.9, "VSS")
When I don't run axlDBCloak and just use the axlDBCreateVia command separately in the skill terminal everything works well. I am creating several hundreds of vias with axlDBCloak. Is there any limitation in this function? is it possible that it will 'misbehave' if it has to execute too many database accesses?
Help appreciated! Thanks!
  • DE202408202727
    DE202408202727 over 8 years ago
    I have had problems with this too. It's to do with when you delete the original via. I have found that deleting the original via, before creating the next one, helps.
  • migrg
    migrg over 8 years ago in reply to DE202408202727
    Hi Dave, thanks for the quick answer. What do you mean delete the original via? I create a different via with each call to axlDBCreateVia. Do you mean create one via, then delete it, then create it again?
  • DE202408202727
    DE202408202727 over 8 years ago in reply to migrg
    I assumed that you were replacing existing vias - which is what I was doing. If I place a new via on top of the old one and then delete the old via, the connections are "confused". I think a Cadence expert can best describe the effects of using cloaking.
  • migrg
    the problem went away by making several 'smaller' calls to axlDBCloak instead. There is some bug with this function and the number of transactions it can queue that is not documented.
  • migrg
    actually I take that back, now I'm calling 100 vias at a time and it's not working. Is there any way to 'flush' the database write after calling axlDBCloak, before calling it again? This is getting really annoying...
