  3. Application modes - axlMiniStatusLoad & PCB Designer desperately...
  • Subscribers 18
  • Views 2172
Application modes - axlMiniStatusLoad & PCB Designer desperately seeking effeciencies
lcan
lcan over 8 years ago
Skill is absolutely not a core competency for me.https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/137/5543.ark.zip However, I am trying to read the documentation, experiment and learn before asking questions.
I can successfully redefine Funckeys, set grids etc.. depending on which App mode I have invoked - however, I would like to use the Mini Status window to display the keys as a form. Yes, I realize this would overwrite options in some App modes, such as "Shapes" - that will be another issue not nearly as pressing for us.
I believe this would be a valuable/sharable utility if I can get it working, so I am here seeking help from the experts. If people could take a look, perhaps someone could see where I am deficient as the form will not display to the options tab, it would be most appreciated.
Bill
  • DE202408202727
    DE202408202727 over 8 years ago
    You need an event to stop this from just exiting.
    Add this:
    eventMask = list('PICK)
    event = axlEnterEvent(eventMask, nil, nil); Normally inside a loop.
    I wouldn't put your axlMiniStatusLoad command in a procedure and this ensures a new form is loaded every time during debugging:
    embFID = gensym()
    fw = axlMiniStatusLoad(embFID, list(sprintf(nil, "embeddedForm_%s", embFID), plForm), nil)
  • lcan
    lcan over 8 years ago in reply to DE202408202727
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/3465.wtm_5F00_pledit.zip
    Dave,
    Thanks for your help!  It took me a few days to get back to this but without your advice I fear I would have never stopped banging my head against that concrete wall :)  I have attached a zip file with placement and etch edit application modes here. Perhaps they are useful for others.. I certainly do not claim what I have to be perfect, but it gets the job done!! Again, thank you so much!
    Bill
