  3. Question for inserting dbid by typing on function
  • Subscribers 19
  • Views 10935
Rascal
Rascal over 8 years ago
Dear all engineers using skill language
I'm a beginner for this language, so maybe it will be a very simple question.
I hoped to use axlDeleteObject function.
axlSingleSelectPoint()
s = axlGetSelSet()
axlDeleteObject(s)
with this code, it works well but,
axlDeleteObject(dbid:394899204)
if I used fucntion like above, it didn't work with error message (E- *Error* eval: unbound variable - dbid)
so here is the main question, how can i convert string(or char) type to dbid type?
Thank you
  • rajeshcad
    rajeshcad over 8 years ago
    It can't be converted. dbId is never the same in every session of tool. If someone is writing a program, its advisable to store the dbid in a variable and pass the variable.
  • Rascal
    Rascal over 8 years ago in reply to rajeshcad
    Thanks, I understand it can be changed whenever I use the tool, but in the same session, the part already placed dbId would not be changed and when I selected it, I could approach its dbId.
    The point of my question is why this code  (axlDeleteObject(dbid:394899204)) can not be worked?
    what is the o_dbid or lo_dbid format, and how can I make these?
    If I use printf function with list of part and it answers dbId:254233152 like this. Then It's not a dbId for that part?
    Thank you for your kindness
  • DE202408202727
    DE202408202727 over 8 years ago in reply to Rascal
    Because dbId:254233152 is not a "thing" it's just a label. You can't use it because it's meaningless.
  • Rascal
    Rascal over 8 years ago in reply to DE202408202727
    Appreciate it
    Now I fully understand
    Thank you again!
