  3. axlSelect() does not select 'fillet'
  • Subscribers 19
  • Views 3523
kwlee
kwlee over 8 years ago
axlSelect()  does not select 'fillet'.
When I use below 3 lines, and try to select fillet at 16.6. there is no item in retVal variable..
Is any one help me???
axlSetFindFilter( ?enabled list( "shapes")  ?onButtons "ALLTYPES")
 axlSelect(?prompt "Select all shapes.")
 retVal=axlGetSelSet()
  • DE202408202727
    DE202408202727 over 8 years ago +1
    Try axlSetFindFilter( ?enabled list( "shapes" "dynthemals") ?onButtons "ALLTYPES")
  • DE202408202727
  • kwlee
    kwlee over 8 years ago in reply to DE202408202727
    Great!!, It works perfectly... Thank you very much.
  • Wizard99
    Wizard99 over 6 years ago in reply to DE202408202727
    Hi,i have a similiar question
    When I use below 3 lines, and try to select fillet at 16.6. there is no item in Cline_List variable..
    Can you help me, Thank you.
    axlSetFindFilter(?enabled '(noall clines clinesegs") ?onButtons '(noall clines clinesegs"))
    axlSelect(?prompt "Select Clines.")
    Cline_List=axlGetSelSet()
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    a fillet is a shape, below is the top part of a 'show element' on a fillet:
    LISTING: 1 element(s)
                 < SHAPE >
           class         ETCH
           subclass      BOTTOM
      part of net name:  CVL_RX_L0_P
      Connected vias:      1
      Shape is solid filled
      Shape is fillet
      Area:   0.000099  (sq in)
