  3. Export DXF and ODB through skill
  • Subscribers 18
  • Views 16551
Eugene Yeoh
Eugene Yeoh over 8 years ago
Hello Guys,
I am try to develop a skill that export dxf and odb with single button, in this skill i aim to auto fill in the name of the layer and directory where the file should save.
Any idea which command we can use that?
I had try to do it with "replay script" but it not user friendly enough that the file name and directory are fixed.
Eugene
  • DE202408202727
    DE202408202727 over 8 years ago
    Don't use a scipt to do this. Use axlRunBatchDBProgram and call th brd2odb executable with the parameters that you want.
  • Eugene Yeoh
    Eugene Yeoh over 8 years ago in reply to DE202408202727
    Hi Dave,
    i try a2dxf but i not able to change the cnv file according to film user wanted to convert to dxf.
    for example:
    initial user manully use ABC.cnv to convert drill film to dxf(user can edit the cnv and save)
    second time user to ABC.cnv to convert soldermask film to dxf.(dxf that export is in drill film as axlRunBatchDBProgram did not include the parameter to edit the contain of cnv)
    any idea how can i edit the .cnv file according to user selected film?
    Eugene
  • Eugene Yeoh
    may i know where can i find brd2odb command line arguments file?since it is from mentor.
    I not able to find inside batchhelp folder
    Thanks alot
    Eugene
  • B Bruekers
    B Bruekers over 8 years ago in reply to Eugene Yeoh
    Look for the Brd2odb_help.pdf in the directory where the ODB++ translator executable of Mentor is placed.
    In the PDF you have a section 'Using Command Line Parameters:'
    The command line is 'brd2odb [parameters] <full path to input brd file>'
    You can see which commands are actually used, put this in the Allegro command prompt: set wait_debug
    Then the axlRunBatchDBProgram() commands are echoed in the commandline.
    The same is valid for the DXF export.
    For a simple DXF export to give you a head start:
    dxfFile = "dxf_output"
    fcnv = "DXF_mapping"
    layer = "TOP"
    p = axlDMOpenFile("ALLEGRO_CNV", fcnv, "w")
    fprintf(p "#This is the Layer Conversion File used for\n")
    fprintf(p "#importing DXF data into Allegro/APD.\n\n")
    fprintf(p "#CLASS!            SUBCLASS!                           DXF_LAYER!\n\n")
    fprintf(p "BOARD GEOMETRY!\n")
    fprintf(p "                   CUTOUT!                             OUTLINE!\n\n")
    fprintf(p "                   DESIGN_OUTLINE!                    OUTLINE!\n\n")
    fprintf(p "PACKAGE GEOMETRY!\n")
    fprintf(p "                   ASSEMBLY_%s!                       PACKAGE!\n\n" layer)
    fprintf(p "PIN!\n")
    fprintf(p "                   %s!                                PIN!\n\n" layer)
    fprintf(p "REF DES!\n")
    fprintf(p "                   DISPLAY_%s!                        REF_DES!\n\n" layer)
    fprintf(p "#END\n")
    axlDMClose(p)
    sprintf(str "a2dxf -$ -u MM -a 3 -f 12 -c L \"%s.cnv\" \"%s/%s_%s.dxf\" %%s" fcnv getWorkingDir() dxfFile layer )
    res= axlRunBatchDBProgram("Generating DXF File... " str  ?noLogview t  ?warnProgram t ?noExitMsgs t)
    deleteFile(strcat(getWorkingDir() "/" fcnv ".cnv"))
    Kr, Bram
  • Eugene Yeoh
    Eugene Yeoh over 8 years ago in reply to B Bruekers
    Hi Kr,Bram
    Thanks for reply, i cannot find the Brd2odb_help.pdf, do you mind to attach one for me?
    Eugene
