  3. axlClearObjectCustomColor only clears nets
  • Subscribers 18
  • Views 8919
RasmusDK
RasmusDK over 8 years ago
Hi Community,
I am currently developing a SKILL script, which will be manipulating the custom colors of nets, pins, vias, clines, shapes and rats, as per the Color Dialog (color192). As part of the program, I want to clear the custom colors everywhere. I have tried using axlClearObjectCustomColor, as seen in the code below. Unfortunately, this code only clears the custom colors of nets. Pins, vias, clines, shapes and rats maintain their custom colors, even after I have called the method on them. From the documentation, the method axlClearObjectCustomColor, takes a list of dbids and returns t/nil, depending on if a color was cleared or not. Why does this not work for anything but nets? Am I dealing with the wrong dbids? I can use the same dbids to get the custom color value...
procedure( clearCustomColors()
nlist = axlDBGetDesign()->nets ;nid = car(axlSelectByName("NET" "1V8"))
axlClearObjectCustomColor(nlist)
foreach(nid nlist
axlClearObjectCustomColor(nid->branches)
axlClearObjectCustomColor(nid->ratsnest)
; Alternative version:
; foreach(nid nlist
; axlClearObjectCustomColor(nid)
; foreach(bid nid->branches
; foreach(cid bid->children
; case(lowerCase(cid->objType)
; ("path"
; isEtch == t means it is a cline
; if(cid->isEtch
; then
; axlClearObjectCustomColor(cid)
; else
; axlMsgPut("Path was not a cline")
; ("pin"
; ("via"
; ("tee"
; axlMsgPut("Tee Type")
; axlMsgPut("Tee Type: %L\n" cid->name)
; ("shape"
; (t
; axlMsgPut("Another type: %L\n" cid->objType)
; foreach(rid nid->ratsnest
; axlClearObjectCustomColor(rid)
