  3. Deleting / Adding subclasses in existing Artwork films
  • Subscribers 20
  • Views 14599
Arashk
Arashk over 8 years ago
With the new version update, Cadence prefers to use DESIGN_OUTLINE and CUTOUT instead of OUTLINE subclass, I wanted to write a script that will go through the existing films in the design and replace the OUTLINE subclass with these two subclasses. (I am very new to SKILL)
I've tried using the ; axlDeleteObject() and axlfcreate()  functions but I could only get them to delete / create films, not subclasses.
Cheers ,
Arash
  • B Bruekers
    B Bruekers over 8 years ago +1
    You need to go through each existing film and replace the outline layer with the designoutline+cutout. If you call axlFilmCreate() with all the existing film parameters and the updated layer list then…
  • Quarkdog1
    Quarkdog1 over 6 years ago in reply to Arashk +1
    Can someone post the skill file for this as. It would be super useful for me.
  • B Bruekers
    If you call axlFilmCreate() with all the existing film parameters and the updated layer list then it will replace this film.
    So something like this:
    procedure(updateFilmTo172()
    let( ( filmParam l_members res)
    foreach(filmStr axlGetParam("artwork")->groupMembers
        filmParam = axlGetParam(strcat("artwork:" filmStr))
        when(filmParam->groupMembers
            ;make all upperCase
            l_members = mapcar('upperCase filmParam->groupMembers)
            ;check if OUTLINE is present
            if(member("BOARD GEOMETRY/OUTLINE"    l_members)
            then
                ;if so, remove it
                l_members = remove("BOARD GEOMETRY/OUTLINE"    l_members)
                ;add 2 new layers
                push( "BOARD GEOMETRY/DESIGN_OUTLINE"    l_members)
                push( "BOARD GEOMETRY/CUTOUT"            l_members)
                res = axlFilmCreate(
                        filmParam->name
                        ?negative                          filmParam->negative
                        ?undefineLineWidth          filmParam->undefineLineWidth
                        ?sequence                   filmParam->sequence
                        ?rotation                   filmParam->rotation
                        ?xOffset                    car(filmParam->offset)
                        ?yOffset                    cadr(filmParam->offset)
                        ?shapeBoundingBox           filmParam->shapeBoundingBox
                        ?mirrored                   filmParam->mirrored
                        ?fullContact                filmParam->fullContact
                        ?suppressUnconnectPads      filmParam->suppressUnconnectPads
                        ?drawMissingPadApertures    filmParam->drawMissingPadApertures
                        ?useApertureRotation        filmParam->useApertureRotation
                        ?suppressShapeFill          filmParam->suppressShapeFill
                        ?vectorBasedPad             filmParam->vectorBasedPad
                        ?drawHolesOnly              filmParam->drawHolesOnly
                        ?layers                        l_members
                        ?domains                    filmParam->domains
                        ?ipc2581                    filmParam->ipc2581
                if(res
                then axlMsgPut('("Film %s \t: Updated" 1) filmParam->name)
                else axlMsgPut('("Film %s \t: Not updated!" 3) filmParam->name)
            else
                 axlMsgPut('("Film %s \t: No update needed." 1) filmParam->name)
    );let
    );procedure
  • Arashk
    Arashk over 8 years ago in reply to B Bruekers
    Thank you, very well written!
  • Quarkdog1
  • BlueSaab37
    BlueSaab37 over 6 years ago in reply to Quarkdog1
    I was able to run this script as-is.
    Save the lines to a text file called "updateFilmTo172.il", and save it in your skill folder.
    Open a board in PCB Editor, click in the command window, and type these lines:
    skill
    load "c:\\<path to skill file>\\updateFilmTo172.il"
    updateFilmTo172
    <click in the command window again>
    exit
    This should change all the film control layers to delete the outline layer, and add the design_outline and cutout layers.
    Note that this does not actually change or move the board outline; this JUST changes the gerber outputs.
    Seth
  • Kirti Sikri
    Kirti Sikri over 6 years ago in reply to BlueSaab37
    You can load a particular SKILL file by typing the following command at the Allegro PCB Editor command line:
         Command > skill load("skill_file_name.il")
    If it is successfully loaded, the PCB Editor command line will report a "t" as the last entry. The SKILL file will only load if the file is present in the SKILL search path. To find the SKILL search path, you can type the following command on the command line:
         Command > skill getSkillPath()
    More details you can refer to the following article:
    How to load and use SKILL files in Allegro PCB Editor
