  3. Skill to import template default
  • Subscribers 19
  • Views 10083
LoGanathan
LoGanathan over 8 years ago
I have a template (abc.dra) by default it has some new layers, text size & colors. While opening any footprint this template need to import automatically. Please help.
Thanks in advance.
  • DavidJHutchins
    DavidJHutchins over 8 years ago
    open your template design file & open File>Export>Parameter..., select all, then export to something like 'default.prm', which you should copy to something like $CDSROOT/share/local/pcb/parameter
    Then in your skill code have something like the following:
    procedure( MyTriggerOpen( t_open)
     let( ()
          axlImportXmlDBRecords("default.prm")
    axlTriggerSet('open 'MyTriggerOpen)
  • LoGanathan
    LoGanathan over 8 years ago in reply to DavidJHutchins
    Thanks for the code. Actually in my template i have text in some layers. That also might need to import by default. I tried the above code, it export/import only the color, layer & text size. Please help.
