  3. X-out on assembly variants
  • Replies 9
  • Subscribers 18
  • Views 12911
VECTORT
VECTORT over 8 years ago
I know that there is an option Manufacture > Variants > Create Assembly Drawing...
but this option makes unpopulated components to disappear, and this is not suitable for documentation for our manufacturing facility.
I know how to go in SKILL through all variants in Variant.lst.
One thing I need is how to draw in skill X of the size of assembly rectangle of the component on certain layer.
Thank you in advance for any tip.
  • DE202408202727
    DE202408202727 over 8 years ago +1
    Something like this: defun( DE_VariantAssemblyDraw (variantSymbols, topLayer, bottomLayer) foreach(sym, variantSymbols bBox = nil objs = setof(obj, sym ->children, memv(obj ->objType, '("path", "shape…
  • DE202408202727
    bBox = nil
    objs = setof(obj, sym ->children, memv(obj ->objType, '("path", "shape", "polygon")) && obj ->layer == strcat("PACKAGE GEOMETRY/ASSEMBLY_", if(sym ->isMirrored, "BOTTOM", "TOP")))
    foreach(obj, objs
    bBox = if(bBox
    then list(list(min(caar(bBox), caar(obj ->bBox)), min(cadar(bBox), cadar(obj ->bBox))), list(max(caadr(bBox), caadr(obj ->bBox)), min(cadadr(bBox), cadadr(obj ->bBox))))
    else obj ->bBox
    newObj = car(axlDBCreateRectangle(bBox, nil, if(sym ->isMirrored, bottomLayer, topLayer), nil, sym))
  • VECTORT
    VECTORT over 8 years ago in reply to DE202408202727
    Thank you eDave.
    I have one more question:
    How I can print dbid attributes ?
    I found in forum that I can use dbid->?? and it will return all the attributes,
    but when I try:
    printf(my_form "some_value: %s", dbid->??)
    I keep getting error that second argument is nil
  • Kirti Sikri
    Kirti Sikri over 8 years ago in reply to VECTORT
    Instead of %s use %L.
    printf(my_form "some_value: %L", dbid->??)
  • VECTORT
    VECTORT over 8 years ago in reply to Kirti Sikri
    No change, this is what I try to do:
    axlClearSelSet()
    axlSetFindFilter(?enabled '(components) ?onButtons '(components))
    result=axlGetSelSet(axlSingleSelectName("COMPONENT" strcat("U10000")))
    printf("Result: %L\n", result->??)
  • VECTORT
    I have another question.
    this bBox creates rectangular area of whole component is it possible to use only one layer from component?
    For example PACKAGE GEOMETRY/DFA BOUND_(TOP,BOTTOM)
    The reason for that is that some components have some elements that are out of PACKAGE GEOMETRY/DFA BOUND_(TOP,BOTTOM) (e.x. SilkScreen) but using bBox sise I am getting bigger Xout that I would like to have (example attached).
