  3. How to export NCDrill, NCRoute in SKILL
  • Subscribers 19
  • Views 11267
yuriyk
yuriyk over 8 years ago
I've been trying to find the solution to this for quite some time, searched all over the forums, but not able to get the information I need.
I am trying to use SKILL to automate exporting NCDrill and NCRoute files. I tried the following script and it give me errors and not drill file.
axlRunBatchDBProgram("nctape" "nctape -$ " ?logfile "ncdrill.log")
errors from log:
ERROR(SPMHMF-335): There was an error extracting the drilling data. [help]
ERROR(SPMHMF-336): Program terminated.
while this script below worked fine, it outputted a gibberish file name: #Taaaabf17304_1-16.rou
axlRunBatchDBProgram("ncroute" "ncroute -v %s " ?logfile "ncroute.log")
When i export NCDrill and NCRoute files manually (or recorded script) through Manufacture>NC>NCDrill/Route, it creates a #designname#.drl
How can i achieve the same with axlRunBatchDBProgram?
Thank you!
  • B Bruekers
    B Bruekers over 8 years ago
    The 'debug' mode can be useful as described in the axlRunBatchDBProgram() documentation:
    For debug, set the env variable, wait_debug, on the Allegro command line:
    set wait_debug
    or in Skill
    axlSetVariable("wait_debug" nil)
    This echos the spawning arguments of your program.
    If i try this on a design i see this command: cmd= nctape -$ -q  -o -n "test.brd" C:/test/#Taaaaac03900.tmp
    Example code which i use to generate NC drill:
    sprintf(str "nctape -$ -q -o -n \"%s.DRL\" %%s", axlCurrentDesign())
    res= axlRunBatchDBProgram("Generating Drill Files... " str ?logfile "ncdrill" ?warnProgram t ?noExitMsgs t)
    The res contains the return status of nctape. t = successful, 1 = warning, 2 = error.
    Further you can look in the Cadence help for 'nctape'. There you can see which parameters the nctape executable accepts
