  3. SKILL console ?
  • Subscribers 18
  • Views 10372
SKILL console ?
VECTORT
VECTORT over 8 years ago
is there possibility somehow to have SKILL console ? Like TCL console in Capture?
If not can you give some tips/advices how quicker develop and test code in SKILL.
Because right now I am writing code in Notepad++ then under Allegro I am importing scritps registering command running command,
and this takes time a lot of time, while I am still learning and doing lots of mistakes.
So repeating this steps all over and over is annoying. SKILL console would speed up testing some basic constructions.
Thank you in advance.
  • DE202408202727
    DE202408202727 over 8 years ago
    Type set telskill in the Allegro command console window
  • VECTORT
    VECTORT over 8 years ago in reply to DE202408202727
    Thanks !
  • B Bruekers
    B Bruekers over 8 years ago in reply to VECTORT
    I use this for quickly reloading one or a set of skill files and restart the code:
    defun( zz ()
        load("<skillfile>")
        load("<additional skillfile>")
        axlShell("done")
        axlShell("<registrated command>")
    By typing 'zz' in the skill console it will (re)load and start the code. It saves you some copy/pasting of 'load' commands during debugging:)
    Bram
