  3. DBID of overlapping components
  • Replies 9
  • Subscribers 18
  • Views 15669
VECTORT
VECTORT over 8 years ago
can you please help me with one more issue.
I need to get dbids of overlapping components in design.
Thank you in advance for any advice.
  • B Bruekers
    B Bruekers over 8 years ago in reply to VECTORT +1
    If you would do it without the Allegro DRC system then you need to check each component to all other components. Quickest way to do this is first check bBox overlap, if so then check if the polygon is…
  • B Bruekers
    Quickest way to do this is first check bBox overlap, if so then check if the polygon is overlapping, meaning an result with 'AND' operation.
    So something like this:
    ;lsym = setof(id axlDBGetDesign()->symbols id->isMirrored)                ;bottom side
    lsym = setof(id axlDBGetDesign()->symbols not(id->isMirrored))  ;top side
    pcre = pcreCompile("package geometry/dfa_bound" 1)
    while(lsym
        id1 = car(lsym)
        lsym = cdr(lsym)
        foreach(id2 lsym
            ;first do a rough compare, compare bbox overlap of ID1 and ID2. This is faster than doing polygon compare
            when( _axlIsBoxOverlap(id1->bBox id2->bBox)
                ;if overlap then do polygon compare
                lchildrenID1 = setof(id id1->children pcreMatchp(pcre    id->layer))
                lchildrenID2 = setof(id id2->children pcreMatchp(pcre    id->layer))
                when(and(lchildrenID1 lchildrenID2)
                    lpolyID1= mapcar('car mapcar('axlPolyFromDB lchildrenID1))
                    lpolyID2= mapcar('car mapcar('axlPolyFromDB lchildrenID2))
                    lANDpoly = axlPolyOperation(lpolyID1 lpolyID2 'AND)
                    when(car(lANDpoly)
                            axlMsgPut("%L @%P - %L @%P have overlapping geometry" id1->refdes id1->xy id2->refdes id2->xy )
    Bram
  • VECTORT
    VECTORT over 8 years ago in reply to B Bruekers
    That works perfect, exactly what I was looking for.
    Nevertheless I have one issue with duplicates.
    I am inserting result into the list and I get:
    (("C24006"  "R24020") ("C16036" "MP32004") ( "R24020" "C24006") ("MP32004" "C16036"))
    So there are duplicates but with different order.
    Can you please help with deleting those duplicates to get list like
    (("C24006"  "R24020") ("C16036" "MP32004"))
    Thank you in advance.
  • B Bruekers
    That is weird. It goes through each symbol and puts it in 'ID1' , but for each ID1 it looks at all other symbols (ID2), excluding the previously checked ID1's.
    So double hits should not occur. If you have double symbol dbID's in the lsym then it is possible.
    Could you try to add the following 'unique' line ?
    lsym = unique(lsym)
    while(lsym
    Otherwise post the code which you have currently.
  • VECTORT
    Yes you are right. I have made mistake in my code. Now it works.
    Thank you !
