  3. DBID of overlapping components
  • Replies 9
  • Subscribers 18
  • Views 15666
VECTORT
VECTORT over 8 years ago
can you please help me with one more issue.
I need to get dbids of overlapping components in design.
Thank you in advance for any advice.
  • B Bruekers
    B Bruekers over 8 years ago in reply to VECTORT +1
    If you would do it without the Allegro DRC system then you need to check each component to all other components. Quickest way to do this is first check bBox overlap, if so then check if the polygon is…
  • Ejlersen
    Ejlersen over 8 years ago
    Hi
    It depends on what you mean by overlapping components, is it 2 place bounds overlapping, pins overlapping or what define if they are overlapping?
    You could setup drc checks for this and run through the DRCs.
    Best regards
    Ole
  • VECTORT
    VECTORT over 8 years ago in reply to Ejlersen
    Our library components have shapes on "PCKAGE GEOMETRY/DFA_BOUND_(TOP,BOTTOM)"
    so I think I would need to find those components which shapes on this layer are overlapping (can touch but cannot go one on the another).
  • Ejlersen
    Ejlersen over 8 years ago in reply to VECTORT
    Hi
    DFA constraints in Allegro are built for this exact purpose and you can even specify spacing between dfa bounds on different component classes.
    You can enable and set this up within Setup->Constraints->DFA Constraint Spreadsheet
    After you've set this up online DRC checking will be performed and you will get a DRC error immediately.
    I once did a movie about this which can be seen on YouTube at https://youtu.be/tyiPnsQqx7Q (it is in Danish but you should get the idea from watching it)
    Will this work for you or do you have another reason for wanting to do this using SKILL?
    Best regards
    Ole
  • VECTORT
    I know this tool but not sure how to use it to achieve my goal.
    The reason I need to find this DBID from inside SKILL is for automatic documentation creation for Production Facility.
    What I need to do is:
    1) find DBID of overlapping components
    2) create layer with surrounding lines arround this 2 or more overlaping components
    Second part I have almost done and it is working well, but I am giving DBIDs manualy, so just need to find somehow this DBIDs
  • Ejlersen
    Hi
    notice that dbid's are not static!
    you could walk over all dfa bounds and do math to find out if they overlap
    l = axlDBGetDesign()->symbols
    foreach(lid l
    refdes = lid->refdes ; get the reference designator
    foreach(cid lid->children
    when(lowerCase(cid->layer) == "package geometry/place_bound_top"
    ; here you have a single geometry and needs to check it against other geometries
    I would however use DFA as stated above and then run over all DRCs to find the objects (components) causing the issue and then create the rectangle
    Best regards
    Ole
