  3. Code/Command to Differentiate Between 17.2 and 16.6
  • Subscribers 19
  • Views 1850
EMperson
EMperson over 8 years ago
I need to code a solution that can tell if a symbol was created in Cadence 16.6, or 17.2. Is there a SKILL function that can do that? Or some other command?
  • B Bruekers
    B Bruekers over 8 years ago
    In the original psm (or bsm,ssm) files there is an version id. Perhaps you can use this?
    It is located in the file at offset 251, and then 5 characters. A possible way to extract this :
    dir = "c:/library"
    l_f = pcreMatchList(pcreCompile(".ssm|.psm|.bsm" 1) getDirFiles(dir))
    t_file = makeTable("file" nil)
    foreach(f l_f p = infile(strcat(dir "/" f)),for(i 1 251 getc(p)),for(i 1 5 t_file[f]= cons(getc(p) t_file[f])),close(p))
    foreach(item sort(t_file->? nil) axlMsgPut("%s: %L" item buildString(reverse(t_file[item]) "")))
    Kr, Bram
  • DE202408202727
    DE202408202727 over 8 years ago
    dbstat gives you this. Pipe the output to a file and read that to give the database version of the design.
    system("dbstat -v mySymbol.psm >mySymbol.dat")
