  3. Creating a output of every DRC used on a design in Allegro...
  • Subscribers 18
  • Views 9112
Creating a output of every DRC used on a design in Allegro 16.6.
tmd63
tmd63 over 8 years ago
We have an eDfM who wants an excel spreadsheet filled out for every Design Rule and compliance with these rules. This creates hundreds of thousands of rules to check on a 12 layer design!
Is it possible to output each design rule and the value of the checks done (IE each pad tested and the minimum clearance value actually found) instead of just reporting that the DRC has zero errors?
If this is possible, how would it be done? Can a report be created in Cadence Allegro 16.6?
  • DE202408202727
    DE202408202727 over 8 years ago
    This is certainly relatively easy to achieve with Skill.
