  3. Creating Context File
  • Replies 7
  • Subscribers 20
  • Views 19203
EMperson
EMperson over 8 years ago
The process for creating context files is unclear to me. I've read the sklanguser.pdf summary, but I'm confused on a few things:
1) How to set up the Directory Structure. If I want to create the context file "HelloWorld.cxt", where should the file "HelloWorld.il" go?
2) I keep getting the error "can't access startup.il". Where should that file be stored? What should the contents of startup.il be?
I just need a super concise, easy tutorial of how to create a context file. Thanks!!
  • DE202408202727
    DE202408202727 over 8 years ago
    I agree, the documentation makes it sound difficult.
    This is a simple way of doing it:
    In a DOS shell, cd to your Skill folder
    Run Allegro Skill by typing:
    il_allegro
    Name your context file:
    setContext("My_context")
    load your Skill file(s) needed to run the code (normally only one):
    load("mySkillFile.il"); This is what startup.il does - you would add a load statement for each Skill file.
    define the initiation process:
    defInitProc("My_context", 'myFunction); Where myFunction is the name of the procedure/function that you want to call in your Skill file.
    Protect your code:
    sstatus(writeProtect t)
    saveContext("My_context.cxt")
  • EMperson
    EMperson over 8 years ago in reply to DE202408202727
    Thanks, this is super helpful! One last thing-- I need to load my code into Allegro PCB Designer, and my code has a command I created using  axlCmdRegister. So how do I load my "My_Context.cxt" file into Allegro, and then run a command?
  • DE202408202727
    DE202408202727 over 8 years ago in reply to EMperson
    Where you previously would have used "load", use "loadContext".
    Be aware that 17.2 context files are in a 64bit folder.
    Run your command the same way as before.
  • EMperson
    I read somewhere that axlCmdRegister() cannot be included in a context file... How do I still use commands?
  • DE202408202727
    I always register commands in the allegro.ilinit file - not the Skill file itself unless I'm debugging.
