  3. Confirm dialog problem before closing a form with 'X'
  • Subscribers 18
  • Views 3653
Arthur Ke
Arthur Ke over 7 years ago
Hi all,
I create a non-block form by axlFormCreate().
I expect that when user click 'x' (right-top side of a form), a window popup and ask if need to save something.
But with my form action function like below, the axlUIYesNo window does not appear and i have no idea why.
procedure( MyFormAct(r_form)
case(r_form->doneState
(3
println("user press X to exit...")
confirm = axlUIYesNo("Do you want to save before exit?" "Test")
println(confirm)
(0 println("Do something."))
command print:
nil
BTW, SPB version is 17.2-2016 S034
  • DE202408202727
    DE202408202727 over 7 years ago
    This was fixed in s038
  • Arthur Ke
    Arthur Ke over 7 years ago in reply to DE202408202727
    Nice to know about that, many thanks for your instant reply.
  • Arthur Ke
    Unfortunately, after update to S048, this problem still exists.
    Below is the complete codes to reproduce the issue: axlUIYesNo() window would be skipped.
    Additionally, if I delete the only button in the form, axlUIYesNo() works again, however, it doesn't help me.
    procedure( MyGUI()
        prog( (file r_form)
            file = CreateFormFile()
            unless(file printf("\nError: fail to create form file") return(nil))
            r_form = axlFormCreate(gensym() file nil 'FormActions t)
            axlTempFileRemove(file)
            axlFormDisplay(r_form)
    procedure( FormActions(r_form)
        (3
            print(confirm)
        (0
            when(equal(r_form->curField "btnTest") println("Do something."))
    procedure( CreateFormFile()
        prog( (formTmpFile fp)
            formTmpFile = axlTempFile()
            fp = outfile(formTmpFile)
            unless(fp return(nil))
            fprintf(fp "FILE_TYPE=FORM_DEFN VERSION=2\n")
            fprintf(fp "FORM FIXED_FONT\n")
            fprintf(fp "FIXED\n")
            fprintf(fp "PORT 38 30\n")
            fprintf(fp "HEADER \"Debug Form\"\n")
            fprintf(fp "TILE\n")
            fprintf(fp "FIELD btnTest\n")
            fprintf(fp "FLOC 1 1\n")
            fprintf(fp "MENUBUTTON \"Test\" 9 3\n")
            fprintf(fp "ENDFIELD\n")
            fprintf(fp "ENDTILE\n")
            fprintf(fp "ENDFORM\n")
            close(fp)
            return(formTmpFile)
        ) ; prog
  • DE202408202727
    DE202408202727 over 7 years ago in reply to Arthur Ke
    If you run this via an interactive command should work. I tested it using axlCmdRegister("MyGUI" 'MyGUI)
    A button lableled with "cancel" can be used to process the "x".
    Here is a bit of a re-write that you might find useful:
    procedure( MyGUI()
    prog( (fStr, embFID)
    fStr = CreateFormStr()
    embFID = gensym(); Use this method although it may not be necessary except for miniStatus form.
    r_form = axlFormCreate(embFID, list(sprintf(nil, "embeddedForm_%s", embFID), fStr), nil, 'FormActions, t)
    case(r_form ->curField
    ("btnTest"
    ("cancel"
    println("user pressed Cancel or X to exit...")
    print(confirm)
    axlFinishEnterFun(), axlFormClose(r_form)
    procedure( CreateFormStr()
    list(strcat(
    "FORM FIXED_FONT\n"
    "FIXED\n"
    "PORT 38 30\n"
    "TILE\n"
    "FIELD btnTest\n"
    "FLOC 1 1\n"
    "ENDFIELD\n"
    "FIELD cancel\n"
    "FLOC 11 1\n"
    "MENUBUTTON \"Cancel\" 9 3\n"
    "ENDFIELD\n"
    "ENDTILE\n"
    "ENDFORM\n"
  • Arthur Ke
    Thanks, eDave, I got the point. It is not concerned with axlCmdRegister().
    If I add button named 'cancel' and only check the curField equal 'cancel', previous issue could be avoided.
    And I also note the difference between click 'cancel' and click 'x' in this way,
    By clicking 'x', the form will forced to close and this cannot be stopped.
    By clicking 'cancel' button, i can decide if i really want to close form.
