  3. Attaching shapes to components
  • Subscribers 19
  • Views 10833
kots
kots over 7 years ago
I am in the middle of a program that checks to make sure all elements for high speed nets have proper voids.
I am wondering if there is a way through Skill to attach a void to a symbol? I am trying to attach the void for each AC Blocking Cap to the capacitor or if a void is missing then create the void and attach it to the cap. I am able to create the voids but I can't figure out how to attach the void to the cap in case the cap gets moved in the future.
I have tried to use axlDBCreateGroup("G1" "generic" group) where group contains the dbid's for the cap and the void but I get the following warning message:
          W- *WARNING* (axlDBCreateGroup): ERROR(SPMHDB-256): This element is not supported by this group type; not added.
I'd like for this to work with both static and dynamic shapes so that is why I am trying to associate the void with the cap. My next steps will be to add route keepouts to the ground layer & signal layer below the ground that is voided. I'd also like to associate the route keepout with the cap.
Any help / ideas will be greatly appreciated!
-K
  • DE202408202727
    DE202408202727 over 7 years ago
    Simple answer is no. A void is a child of a shape so only the shape can be attached. The correct way to do this is to add a Route Keepout. Their properties are more flexible than they used to be and can be attached to symbols.
  • kots
    kots over 7 years ago in reply to DE202408202727
    Thanks Dave! I figured that would be the case but wanted to ask just in case. I'll go with the route keepout method as I already got that figured out, I think.
    -K
  • Andak
    Andak over 7 years ago
    Try this part of code, addapting it to your needs. I am not allowed to provide the full code. It is working for me. basically you need to get the list of layers to figure out which one is under the surface and select a bunch of pins.
    foreach( SelectedPIN MyPinList
            PinCuPoly = car(axlPolyFromDB(SelectedPIN ?layer "ETCH/TOP"))
            if(PinCuPoly != nil then
                ;PinCuPoly = car(axlPolyFromDB(SelectedPIN ?layer "ETCH/TOP"))
                axlDBCreateShape( PinCuPoly t strcat("ROUTE KEEPOUT/" LayerUnderTop) nil SelectedPIN->parent)
            else
                PinCuPoly = car(axlPolyFromDB(SelectedPIN ?layer "ETCH/BOTTOM"))
                axlDBCreateShape( PinCuPoly t strcat("ROUTE KEEPOUT/" LayerUnderBottom) nil SelectedPIN->parent)
