  3. axlShell("replay SCRIPT.scr") command in SKILL code not...
  • Replies 9
  • Subscribers 18
  • Views 9398
axlShell("replay SCRIPT.scr") command in SKILL code not working-- "W- Cannot exit current application E- Can't find window; form.film_control"
EMperson
EMperson over 7 years ago
I created some code in SKILL that attempts to run the script, "SCRIPT.scr".
SKILL CODE:
___________________________________
SCRIPT.scr:
setwindow pcb
trapsize 47451
placementedit
artwork
setwindow form.film_control
FORM film_control filmtree popup Add 01_Top
fillin "File"
FORM film_control ok
setwindow pcb
placementedit
_____________________________________
When I type "replay SCRIPT1.scr" into the Allegro command window, the script works perfectly. But when I call axlShell("replay SCRIPT.scr") in my code, two errors pops up:
______________________________________
Any ideas why these errors are popping up, and what I can do to avoid them?
  • DE202408202727
    DE202408202727 over 7 years ago in reply to EMperson
    Have you registered your "txt" command as interactive or general?
  • EMperson
    EMperson over 7 years ago in reply to DE202408202727
    General? I looked up the documentation for each ?cmdType, but I still don't understand the difference
  • EMperson
    EMperson over 7 years ago in reply to EMperson
    So I switched to using "General" for the cmdType, and just axlShell() for my code and it works :) Thanks!
  • Duc Nguyen SV
    Duc Nguyen SV over 7 years ago in reply to EMperson
    I wonder why  "General" is works ! ???
