  3. axlShell("replay SCRIPT.scr") command in SKILL code not...
  • Replies 9
  • Subscribers 18
  • Views 9397
axlShell("replay SCRIPT.scr") command in SKILL code not working-- "W- Cannot exit current application E- Can't find window; form.film_control"
EMperson
EMperson over 7 years ago
I created some code in SKILL that attempts to run the script, "SCRIPT.scr".
SKILL CODE:
___________________________________
SCRIPT.scr:
setwindow pcb
trapsize 47451
placementedit
artwork
setwindow form.film_control
FORM film_control filmtree popup Add 01_Top
fillin "File"
FORM film_control ok
setwindow pcb
placementedit
_____________________________________
When I type "replay SCRIPT1.scr" into the Allegro command window, the script works perfectly. But when I call axlShell("replay SCRIPT.scr") in my code, two errors pops up:
______________________________________
Any ideas why these errors are popping up, and what I can do to avoid them?
  • DE202408202727
    DE202408202727 over 7 years ago
    Works ok for me. Try adding this to your code before calling the script:
    unless( axlOKToProceed(), axlShell("done"))
  • EMperson
    EMperson over 7 years ago in reply to DE202408202727
    Your skill code works too? I tried adding your code to my code but it still isn't working
  • DE202408202727
    DE202408202727 over 7 years ago in reply to EMperson
    Yes. The Skill code works. Are you running it on the Skill command line or in an Allegro console?
  • EMperson
    I'm running the Skill code by typing "skill load test.il" and then typing a command ("txt") which runs axlShell("replay SCRIPT1.scr")... into the Allegro command line
  • EMperson
    EMperson over 7 years ago in reply to EMperson
    Update-- Using "axlShellPost()" instead of "axlShell()" seemed to fix the problem
