  3. getting class and subclass from ministatus
  • Subscribers 17
  • Views 10926
Ejlersen
Ejlersen over 7 years ago
Hi
I'm using a mini status window and is for the first time using the builtin class and subclass fields.
But when I read the fields using axlFormGetField then I get a numeric value back.
I've searched everywhere in the manual and looked over all axl commands with layer, class etc. to figure out how I can get from the numeric to the class/subclass which is what I'm looking for,
Any hints is really appreciated, thanks.
Best regards
Ole
  • DE202408202727
    DE202408202727 over 7 years ago
    Yes, I have had frustrations with this over the years. However, because the effect is to change the active layer, you can just use axlGetActiveLayer to see what values are set.
  • Ejlersen
    Ejlersen over 7 years ago in reply to DE202408202727
    Hi Dave
    Thank you, I should have paid more attention to the deskription when mentioning active layer :-)
    /Ole
  • Ejlersen
    Hi Dave
    Just for the record, axlGetActiveLayer and axlSetActiveLayer are set to obsolete but probably still works. They are replaced with axlDBControl and works fine with class/subclass in ministatus.
    /Ole
