  3. grids.il program stopped working when used in v17
  • Replies 7
  • Subscribers 18
  • Views 12963
joma
joma over 7 years ago
Hi, I have been using  the program grids.il form this forum in v16.6 for several years. After I used it
in v17.2 S050 I got the error:-  *Error* axlFormSetField: argument #1 should be any user-defined (other) type (type template = "otg") - nil
To make things worse now I am getting the same error in v16.6. None of my other skill programs is showing the same error.
I have some colleagues who also have the same problem on different computers.
Any ideas ?
https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/137/6560.grids.zip
  • DE202408202727
    DE202408202727 over 7 years ago
    It works for me in 17.2 although the code is very old and could be written a lot better now.
    The message you are getting implies the form wasn't created, isn't being created in the working directory or "." isn't in your formpath.
  • DE202408202727
    DE202408202727 over 7 years ago in reply to DE202408202727
    Attached is an updated version that uses embedded forms and no scripts. It should be more portable,https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/7534.DE_5F00_grids.zip
  • craigl
    craigl over 7 years ago in reply to DE202408202727
    Hi Dave,
    You might want to replace axlDBGridGet("TOP") to axlDBGetGrid(axlConductorTopLayer()). This will make it useful in the packaging tools as well.
    Regards, Craig
  • joma
    joma over 7 years ago in reply to DE202408202727
    Thanks for the updated version Dave. It's working for me now.
  • joma
    Dave, I made a cut down version that sets all of the grids at once and is the minimum form size.
    This suit the way that I work with the form permanently in the corner of my second screen.
    Only problem is that  I have not been able to get the manual input to work. Any chance you could
    tell me why?
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/2656.grids_5F00_simple_5F00_3_2D00_1.zip
