  3. How to select object based on shape
  • Replies 9
  • Subscribers 18
  • Views 17777
SAKTHIVEL R
SAKTHIVEL R over 7 years ago
Hi All,
        I want to select the object(Pin, Via & Symbol) based on the shape. please help on this.
Sakthivel
  • B Bruekers
    B Bruekers over 7 years ago in reply to SAKTHIVEL R
    The axlAddSelectPoly() command is introduced in one of the latest hotfixes, in HF050 it is for sure available.
    Bram
  • SAKTHIVEL R
    SAKTHIVEL R over 7 years ago in reply to B Bruekers
    Thanks for your quick response, I am using HF049. I will install the latest hotfix.
    Sakthivel
  • hongjing
    hongjing over 7 years ago in reply to B Bruekers
    Hi Bruekers, could you show me where can I get the introduction about axlAddSelectPoly()? thank you. I am writing a code that should use this command.
  • B Bruekers
    B Bruekers over 7 years ago in reply to hongjing
    More than this I dont know:
    arglist('axlAddSelectPoly) -> (l_poly \@optional g_checkVoids (trapEnable 't) "ggg")
