  3. How to select object based on shape
  • Replies 9
  • Subscribers 18
  • Views 17776
SAKTHIVEL R
SAKTHIVEL R over 7 years ago
Hi All,
        I want to select the object(Pin, Via & Symbol) based on the shape. please help on this.
Sakthivel
  • DE202408202727
    DE202408202727 over 7 years ago
    Please elaborate. It's hard to know what you mean from your question.
  • SAKTHIVEL R
    SAKTHIVEL R over 7 years ago in reply to DE202408202727
    Hi Dave,
                 Thanks for your response, I Want to select object based on static or dynamic shape covered area.
    Please refer below image,
    If I select VIN_5V shape it act as a selection boundary and able to select Symbols, Pins and Vias in that area.
  • DE202408202727
    DE202408202727 over 7 years ago in reply to SAKTHIVEL R
    At a very basic level (probably sufficient for you) you can use axlGeoPointInShape. eg setof(obj, pinsViasAndSymbols, axlGeoPointInShape(obj ->xy, shp_dbid))
  • B Bruekers
    B Bruekers over 7 years ago in reply to SAKTHIVEL R
    Something like this:
    axlSetFindFilter(?enabled '("noall" "shapes") ?onButtons '("shapes"))
    when(axlSelect(?prompt "select shape")
        sel = car(axlGetSelSet())
        poly = car(axlPolyFromDB(sel))
        axlClearSelSet()
        axlSetFindFilter(?enabled '("noall" "pins" "vias") ?onButtons '("pins" "vias"))
        axlAddSelectPoly(poly t)  ;t = include voids
        l_sel = axlGetSelSet()
        axlClearSelSet()
        pprintln(l_sel~>objType)
        axlHighlightObject(l_sel t)
  • SAKTHIVEL R
    SAKTHIVEL R over 7 years ago in reply to B Bruekers
    Hi Bruekers,
                     "axlAddSelectPoly" this axl command is not available in Allegro17.2
    Please advise any other command for this.
    Please see my program below.
    axlVisibleDesign(nil)
    axlVisibleLayer(strcat("VIA CLASS/" axlConductorTopLayer()) t)
    axlVisibleLayer("SUBSTRATE GEOMETRY/SOLDERMASK_TOP" t)
    axlVisibleUpdate(t)
    axlSetFindFilter(?enabled '("noall" "Shapes") ?onButtons '("noall" "Shapes"))
    axlAddSelectAll()
    shapeid = axlGetSelSet()
    axlClearSelSet()
    one = car(shapeid)
    axlSetFindFilter(?enabled '("noall" "Fingers") ?onButtons '("noall" "Fingers"))
    axlAddSelectBox(one->bBox)
    axlClearSelSet()
    if any shape without finger how to eliminate that.
    Sakthivel.R
