  3. Build panel milling with skill
  • Replies 8
  • Subscribers 18
  • Views 13800
ENEGUE
ENEGUE over 7 years ago
Hi Guys,
I am trying to build milling for panel based on outline.
axlSetFindFilter ?enabled (list "linesegs" "shapes") ?onButtons (list "alltypes")
axlAddSelectAll()
axlGetSelSet()
after axlGetselSet() i got alot of the segment dbid but not sure how to continues. =(
Can someone share me some idea or sample code?
Eugene
  • Ejlersen
    Ejlersen over 7 years ago in reply to ENEGUE
    Hi
    Since you don't know if the segments are in order you would first need to get them ordered so they form a closed polygon.
    From there you can create a temporary shape that you can expand to get your milling path and then delete the temp shape.
    This is exactly the reason that outline was changed to design_outline - the outline layer was used for all kinds of things and there was no way of telling if it was a closed polygon or not, as an example the closed polygon form on design_outline is actually used when you do zones for flex-rigid PCBs but thats another story.
    Best regards
    Ole
  • DE202408202727
    DE202408202727 over 7 years ago in reply to ENEGUE
    As Ole points out, you should only do this with shapes. If you must use the outline layer then I suggest that you use Shape/Compose to convert the line segments into a shape before you start. It is bad practice to have anything on the outline layer that is not a shape.
  • ENEGUE
    ENEGUE over 7 years ago in reply to DE202408202727
    Thanks Ole and Dave for your input..=)
    Eugene
