  3. Build panel milling with skill
  • Replies 8
  • Subscribers 18
  • Views 13799
ENEGUE
ENEGUE over 7 years ago
Hi Guys,
I am trying to build milling for panel based on outline.
axlSetFindFilter ?enabled (list "linesegs" "shapes") ?onButtons (list "alltypes")
axlAddSelectAll()
axlGetSelSet()
after axlGetselSet() i got alot of the segment dbid but not sure how to continues. =(
Can someone share me some idea or sample code?
Eugene
  • DE202408202727
    DE202408202727 over 7 years ago
    Assuming that you are using 17.2 you should use axlDBGetShapes:
    outlineShape = car(axlDBGetShapes("BOARD GEOMETRY/DESIGN_OUTLINE"))
    polygon = car(axlPolyFromDB(outlineShape))
  • ENEGUE
    ENEGUE over 7 years ago in reply to DE202408202727
    Hi Dave,
    Thanks for your reply
    after translate it into polygon, i can use expand poly right?
    exp_poly = (axlPolyExpand polygon 1.6 'ALL_ARC)
    axlDBCreateShape(exp_poly t "board geometry/Ncroute_path")
    got this error: W- *WARNING* (axlDBCreateOpenShape): Object should be either an r_path or an o_polygon -
    Eugene
  • DE202408202727
    DE202408202727 over 7 years ago in reply to ENEGUE
    axlPolyExpand returns a list so you need to process all the elements in that list (probably just one)
  • ENEGUE
    Wonderful, with car i manage to get it..FINALLY, thanks you so much Dave..
  • ENEGUE
    ENEGUE over 7 years ago in reply to ENEGUE
    but how about segment? currently we still using outline (line segment) instead of design_outline.
