  3. Decompose shape using skill
  • Subscribers 19
  • Views 11573
ENEGUE
ENEGUE over 7 years ago
Hi Guys,
I try to using skill to decompose shape but it only able to decompose one shape, second shape it will show error msg..=(
Error msg:
dbid:removed
W- *WARNING* (axlPolyFromDB): Invalid database id argument - dbid:removed
E- *Error* fprintf/sprintf: format spec. incompatible with data - "Format is 'decompose shape;setwindow pcb;pick %f %f;setwindow pcb;prepopup;Done', argument #1 is nil"
axlCmdRegister( "seg" `milling ?cmdType "General")
procedure( milling()
;open ncroute layer only and get shapes
axlShell("QtSignal ColorVisibilityPane CVPGlobalVisOff clicked")
axlVisibleLayer("BOARD GEOMETRY/NCROUTE_PATH" t)
shapes = _EXfindAllOfType("SHAPES")
foreach( shape shapes
;Convert shape to poly and random get vertices from poly
shape_poly = car( axlPolyFromDB(shape))
shape_vertices = caar(shape_poly-> vertices)
shape_x = car(shape_vertices)
shape_y = car(cdr(shape_vertices))
axlShell(sprintf(nil "decompose shape;setwindow pcb;pick %f %f;setwindow pcb;prepopup;Done" shape_x shape_y))
Any idea?
Eugene
  • B Bruekers
    B Bruekers over 7 years ago
    The 'dbid:removed' is caused by the axlShell(), after the first axlShell() all dbid's in 'shapes' are removed.
    You want to create lines of out shapes right? Try something like this:
    axlVisibleDesign(nil)
      ;Convert shape to path
      path = axlDB2Path(shape)
      axlDBCreatePath(path "BOARD GEOMETRY/NCROUTE_PATH" 'line nil nil)
    By converting the shape into a rpath you can create a line from it.
    Bram
  • ENEGUE
    ENEGUE over 7 years ago in reply to B Bruekers
    Thanks Bram, i got it...thanks=)
    Eugene
