  3. Difference between SPB16.6 and SPB17.2 for skill
  • Subscribers 18
  • Views 9126
hongjing
hongjing over 7 years ago
Hi master,
I met a problem using skill. it is OK in Allegro 16.6, but when I use it in 17.2 it will have some problem, I make a funckey for that, for example: funckey F2 c2s, c2s is a command of skill program.
in Allegro I type F2 to run this skill, it will work, but other commands for allegro do not work, i need right click and done this skill command, then all commands work well. it never happen in 16.6, anyone can explain that? how can I fix that problem?
