  3. Compare Keepout Shapes
  • Subscribers 17
  • Views 10872
EdwinB
EdwinB over 7 years ago
Hi experts,
Is there a way to compare the KEEPOUT Shapes (KOS) between designs? For example, I have an ECO board that I would like to know what/which KOS changed? Is there a way to compare the eco with the original board? If so, how do I go about it? Also, is there a Skill code available to do this check?
Edwin B
  • DE202408202727
    DE202408202727 over 7 years ago
    An easy way to do this would be to generate an artwork film for your original board keepout layer and import it into the new board on a documentation layer to do the comparison.
  • EdwinB
    EdwinB over 7 years ago in reply to DE202408202727
    Hi Dave,
    Thank you for your reply. I'll do as you've suggested. Hopefully, this will resolve my issue.
    Edwin.
  • EdwinB
    Hi Dave,
    How do you create a 'documentation layer' when the available Class is limited to Etch, Board Geometry, Drawing Format, and Manufacturing? I tried creating a KOZ layer as a subclass on each of the available Class definitions but somehow the artwork won't show. Might be something wrong with how I made the layer. How do you go about it?
    Ed
  • DE202408202727
    DE202408202727 over 7 years ago in reply to EdwinB
    I would just create a temporary layer in any non-etch class. Say MANUFACTURING/COMPARE
  • EdwinB
    Thanks Dave, it works!
    Ed.
