  3. Add part_number to component in PCB
  • Subscribers 17
  • Views 11219
Ejlersen
Ejlersen over 7 years ago
Hi
I'm creating a board file using SKILL with axlDBCreateComponent.
The problem is how I get a part_number assigned to the parts created with this method.
Since I create symbols and device files before creating the board data, I'm wondering if this is tied into the device file which is writted using axlWriteDeviceFile .
For some parts I've used the line below and are wondering what the empty list could containt. Documentation on this command is a bit sparse.
axlCreateDeviceFileTemplate(devicefilename "MECHANICAL" '())
Any suggestions?
Best regards
Ole
  • DE202408202727
    DE202408202727 over 7 years ago
    For what it's worth, here's a function that I use to create a component:
    defun( ARY_AddVscoreDogBoneSymbol (symName, loc, ang)
    let((symDef, nPins, deviceFileName, p, names, nList, n, refdes, net, sym, suff, netName, netNameOther); drcs
    symDef = axlLoadSymbol("package", symName)
    nPins = length(symDef ->pins)
    deviceFileName = strcat(symName, ".txt")
    unless(axlDMFindFile("DEVICE_MAP", symName, "r")
    p = axlDMOpenFile("DEVICE_MAP", deviceFileName, "w")
    when(p
    fprintf(p, "(DEVICE FILE: %s)\n", symName)
    fprintf(p, "PACKAGE %s\n", symName)
    fprintf(p, "CLASS IO\n")
    fprintf(p, "PINCOUNT %d\n", nPins)
    fprintf(p, "END")
    drain(p)
    axlDMClose(p)
    ;Delete unplaced dogbone symbols:
    axlDeleteObject(setof(c, axlDBGetDesign() ->components, Left(c ->name, 8) == "DOGBONE_" && !(c ->symbol)))
    ;caclulate the dogbone name by finding the lowest number available:
    names = axlSelectByName("COMPONENT", "dogbone_*", t) ~>name, axlClearSelSet()
    nList = sort(mapcar(lambda((cName), readstring(cadr(parseString(cName, "_")))), names), 'greaterp)
    n = (car(nList) || 0) + 1
    for(i, 1, car(nList) || 0, unless(listnindex(nList, i), n = i))
    sprintf(refdes, "DOGBONE_%d", n)
    axlDBCreateComponent(refdes, symName); Uses device file [devName].txt
    deleteFile(deviceFileName)
    ;Create the symbol:
    sym = car(axlDBCreateSymbol(refdes, loc, nil, ang))
    if(sym then
    ;Allocate unique net to each set of pins on each side and end of the dogbone:
    foreach(pin, sym ->pins
    suff = strcat(if(axlDBGetPad(pin, "PIN/TOP", "regular") ->figure then "T" else "B"), if(zerop(ang) && car(pin ->xy) < car(loc) || !zerop(ang) && cadr(pin ->xy) < cadr(loc), "L", "R"))
    netName = strcat(refdes, "_", suff)
    netNameOther = strcat(refdes, "_", Left(suff, 1), if(Right(suff, 1) == "L", "R", "L"))
    net = axlDBCreateNet(netName)
    axlDBAssignNet(pin, net)
    axlDBAddProp(pin, list("NET_SHORT", strcat(netName, ":", netNameOther)))
    axlDBRefreshId(nil)
    axlDBAddProp(sym, '(("ARRAYTYPE", "VSCORE_DOGBONE"), ("fixed"), ("locked")))
    axlDBRefreshId(sym)
    else
    printf("Cannot place dogbone at %L. Remove flooding and re-try\n", loc)
    sym
  • Ejlersen
    Ejlersen over 7 years ago in reply to DE202408202727
    Hi Dave
    Thanks, unfortunately not really helping. I've got no problem creating components or symbols, I'm doing that in a lot of different utilities.
    The challenge is if there is any other way than logic import to get part numbers (Part_Number) assigned to components.
    I'll have to dig more into device files in the help for third party logic, maybe its info that could be in the device file. I also got a manual device file creation function similar to yours where you basically write it from scratch, so that could be a way forward.
    Thanks for your input. If I find a solution I'll post it here.
    Best regards
    Ole
  • B Bruekers
    B Bruekers over 7 years ago in reply to Ejlersen
    Once the component has been created you can attach it as a property to the comp definition:
    axlDBAddProp(car(axlDBGetDesign()->compdefs) '(PART_NUMBER "test123"))
      Properties attached to component definition
        PART_NUMBER       = test123
    So this also works:
    id= axlDBCreateComponent( refdes pkgName nil nil nil)
    axlDBAddProp(id->compdef '(PART_NUMBER "test123"))
    Bram
  • Ejlersen
    Ejlersen over 7 years ago in reply to B Bruekers
    Hi Bram
    Thank you so much, off course its a compdef property - why did I not think about that :-(
    Really appreciated the help.
    Best regards
    Ole
