  3. Create Via Structure using SKILL
  • Subscribers 18
  • Views 9608
ycKueh
ycKueh over 7 years ago
Hi Everyone,
I have manually created a via structure constains lot of stacked via and clines, but I need to disband it, delete 1 via and re-create as a new via structure.
Does anyone know any SKILL code to auto select the via structure, disband it, delete some item and re-create another via structure?
I have tried axlDBCreateSymbol('("xyz_L3_L36" "MECHANICAL") 4500:5000 nil nil) , so I can attach all the vias and clines but error message popup below:
(SPMHA1-161): Cannot open the design because of database problems. Run the dbdoctor command on the design and try to open again.
Help please!!
Thank you.
