  3. Get a size of part outline
  • Replies 9
  • Subscribers 19
  • Views 15221
Rascal
Rascal over 7 years ago
I'm trying to get a size of symbol's outline
I used axlDBGetExtents, but it only answers (0:0 0:0).
Help me to get a value of symbol's outline
  • DE202408202727
    DE202408202727 over 7 years ago in reply to Rascal +1
    It's not clear what you want. You could try axlDBGetExtents(axlDBGetShapes("PACKAGE GEOMETRY/PLACE_BOUND_TOP"), nil)
  • Ejlersen
    Ejlersen over 7 years ago in reply to Rascal +1
    Hi Explaining these in detail is a long story. In short Bounding Box is always the smallest rectangle embracing an object (or selection) The result is the lower left corner and upper right corner …
  • Jason Hsu
    Jason Hsu over 7 years ago in reply to DE202408202727
    Hi Dave,
      axlDBGetExtents(axlDBGetShapes("PACKAGE GEOMETRY/PLACE_BOUND_TOP") is the extent if multi shapes exist on one layer.
      car(axlDBGetShapes("PACKAGE GEOMETRY/PLACE_BOUND_TOP")) ->bBox is only for one shape's extent, right? I learn one tip from you againSlight smile.
  • DE202408202727
    DE202408202727 over 7 years ago in reply to Jason Hsu
    Yes
  • Rascal
    Rascal over 7 years ago in reply to DE202408202727
    Hi Dave, I also tried your comment but it's not what I want.
    What I really want is the shape of symbol on Place_Bound_Top Layer
    Because of library conditions, maybe, or my miss understanding of Allegro PCB Tools, I couldn't get proper data with axlDBGetExtents.
    Also, I found the value of my symbol Extents at Design Parameter tap (from mouse right click option), but the value was weird like Left X : -1000, Lower Y : -987.5000, Width 2000, Height 2000. (Maybe it's not the value that you mentioned.)
    Anyway, I could found the value of symbol's shape at bBox value among the symbol's children properties, which objType was shape
    I'm still confused with the meaning of Extent, shape and bounding box.
    I'd appreciate if you explain how they are diffrent.
  • Ejlersen
    Hi
    Design Extent. This is like a piece of paper that has a width and height. Left x is the leftmost x-coordinate and Lower Y is the bottom y-coordinate of the paper.
    So if you have a board that is 2000x2000 with lower left -1000 and lower Y -987.5 then the coordinate of the bottom left corner of the paper is -1000,-987.5 - in other words your 0,0 is placed approximately at the center of the paper - namely 1000 units in the x direction and 987.5 units in the y-direction
    If you then have a shape, whatever type or size, it will have a bounding box. Your Board or footprint will have extents.
    Hope this helps
    Ole
