  3. Get a size of part outline
  • Replies 9
  • Subscribers 19
  • Views 15220
Rascal
Rascal over 7 years ago
I'm trying to get a size of symbol's outline
I used axlDBGetExtents, but it only answers (0:0 0:0).
Help me to get a value of symbol's outline
  • DE202408202727
    DE202408202727 over 7 years ago in reply to Rascal +1
    It's not clear what you want. You could try axlDBGetExtents(axlDBGetShapes("PACKAGE GEOMETRY/PLACE_BOUND_TOP"), nil)
  • Ejlersen
    Ejlersen over 7 years ago in reply to Rascal +1
    Hi Explaining these in detail is a long story. In short Bounding Box is always the smallest rectangle embracing an object (or selection) The result is the lower left corner and upper right corner …
  • Ejlersen
    Hi
    Can you give more details?
    Are you within a board or a symbol.
    If you're within a symbol what outline are you looking for, place_bound, dfa or something else
    Best regards
    OIe
  • DavidJHutchins
    DavidJHutchins over 7 years ago
    I think axlDBGetExtents only works with physical objects (such as symbol, shape, lines), not logical objects ( such as components, functions & nets )
    below is an example of getting a symbol's outline, I only have package geometry/place_bound_top visible:
    \i (00:04:27) skill db1=car(axlGetSelSet())
    (00:04:27) dbid:357367248
    \i (00:04:30) skill db1->??
    (00:04:30) (prop nil bBox
    (00:04:30) ((1756.0 1364.4)
    (00:04:30) (2980.5 1964.4)
    (00:04:30) ) readOnly
    (00:04:30) t pins
    (00:04:30) (dbid:359594208 dbid:360335600) objType "symbol"
    (00:04:30) embeddedAttach nil embeddedMethod nil embeddedLayer
    (00:04:30) nil embedded nil fixedByTestPoint nil
    (00:04:30) component dbid:357309280 xy
    (00:04:30) (1876.0 1732.5) type
    (00:04:30) "PACKAGE" rotation 0.0 refdes "FB18"
    (00:04:30) parent dbid:297174832 name "SFB1612A" definition
    (00:04:30) dbid:357356208 mirrorType "NO" isMirrored nil
    (00:04:30) etchChildren nil children
    (00:04:30) (dbid:360907216 dbid:360907296 dbid:360907376 dbid:360907464 dbid:360907552
    (00:04:30) dbid:360907640 dbid:360907720 dbid:360907800 dbid:360907880 dbid:360908432
    (00:04:30) dbid:360908664 dbid:360908920 dbid:360909152 dbid:360909344 dbid:360909536
    (00:04:30) ) parentGroups
    (00:04:30) nil
    (00:04:30) )
    \i (00:04:56) skill 'axlDBGetExtents(db1 nil)'
    (00:04:56) ((1756.0 1364.4)
    (00:04:56) (2980.5 1964.4)
    (00:04:56) )
    \i (00:05:08) skill 'axlDBGetExtents(db1 t)'
    (00:05:08) ((1803.5 1364.4)
    (00:05:08) (2980.5 1964.4)
    (00:05:08) )
  • Rascal
    Rascal over 7 years ago in reply to Ejlersen
    My experience of this tool is not enough that I couldn't give you a proper Information.
    Maybe, for me, place_bound is needed.
    Also, Could you explain what dfa is?
    It would be helpful for my future automation development
  • Rascal
    Rascal over 7 years ago in reply to DavidJHutchins
    But I did same code, still it only showed me nil
    Is there any settings or something else that prior to get a extents from symbol ?
  • DE202408202727
