  3. How can I perform auto format Cadence Skill, such as indent...
  • Replies 7
  • Subscribers 19
  • Views 8541
How can I perform auto format Cadence Skill, such as indent, align...
Zest
Zest over 7 years ago
The official tools 'SKILL IDE' do not have this feature.
Sometimes my 1st edtion skill source code's format looks like a mess and it will take me a long time to do the code format work like indent,align ...
So my question :
Is there any plugins OR ways to do auto format Cadence Skill source code?
THX!
  • B Bruekers
    B Bruekers over 7 years ago
    First start with a good text editor which can handle indentation and folding correctly.  The issue is that the SKILL dialect of LISP is a not very well known language, so a specific language file for SKILL are rare.
    Some time ago I've switched from NP++ to sublime, it makes a big difference in configuring and using it for coding. You can code your SKILL language file in such way that you can even x-ref functions, so jumping to the definition and see where it is used throughout the project.
    Further, if you pp() (pretty print) your function then you will always get a 'default' format. However you will lose all your comments and in most cases the pp() result also makes it less readable.
    Assume that you've defined a test() procedure. Just use pp(test) to pretty print this function.  If you pass a port as 2nd variable to pp() then you can print it to an file outport.
  • Zest
    Zest over 7 years ago in reply to B Bruekers
    Thanks a lot. pp()  function can resolve this issue perferctly  :)
  • Zest
    Hi Bruekers
    Append a further question.Is there anyway I can stream out pp() log to a temp file, then use this temp file to overwrite my 1st ugly-format skill source code?
    by doing this, I can automatically refresh my skill code format.
    ex:
    load(MyPreocedure.il)
    pp(MyPreocedure) > TEMP.txt
    sh("cp  MyPreocedure.il MyPreocedure.bk.il -f")
    sh("mv TEMP.txt  MyPreocedure.il -f")
    the phrase
    'pp(MyPreocedure) > TEMP.txt'  does not work for now   :(
  • B Bruekers
    B Bruekers over 7 years ago in reply to Zest
    This should work:
    when(p = outfile("./TEMP.txt")
        pp(MyPreocedure p)
        close(p)
  • Zest
     pp(MyPreocedure p) stream out the string "MyPreocedure" to port p, instead of the actual procedure name which MyPreocedure point to,
    I tried using pp(stringToSymbol(name_procedure) p)
    but it still does not work
    Thank you again for your kindness reply :)
