  3. Cut Segment
  • Subscribers 18
  • Views 11095
Cut Segment
ENEGUE
ENEGUE over 7 years ago
Hi Guys,
I am trying to develop a script to cut the segment 2mm apart, center of the line selected by user.
but i not sure how to create script that can cut multiple segment without re-run the script.
Here is my content, hope to get some input from you.=)
axlCmdRegister( "millin2g" `cutsegment ?cmdType "general")
(defun cutsegment ()
line_ya = 0
line_yb = 0
line_xa = 0
line_xb = 0
loop = t
gap = 2
while( loop
axlClearSelSet()
axlSetFindFilter( ?enabled (list "noall" "linesegs") ?onButtons (list "alltypes"))
axlSelect()
line = car(axlGetSelSet())
line_type = line->lineType
if(line_type == nil then
axlUIWPrint(nil "Please select line" )
axlClearSelSet()
axlShell("done")
loop = t
else
line_center = axlMidPointLine(list(car(line->startEnd) car(cdr(line->startEnd))))
case( strcat(line_type)
("horizontal" ;y is same from point xa to xb
line_xa = car(axlMidPointLine(line->startEnd))- gap
line_xb = car(axlMidPointLine(line->startEnd))+ gap
line_ya = car(cdr(line_center))
line_yb = line_ya
axlShell("done")
axlClearSelSet()
_cut(line_xa line_ya line_xb line_yb)
loop = nil
("vertical" ;x is same from point ya to yb
line_xa = car(line_center)
line_xb = line_xa
line_ya = car(cdr(axlMidPointLine(line->startEnd)))- gap
line_yb = car(cdr(axlMidPointLine(line->startEnd)))+ gap
axlShell("done")
axlClearSelSet()
loop = nil
Eugene
  • ENEGUE
    This is my cut function
    (defun _cut (xa ya xb yb)
    ;perform cut
    axlShell("delete;prepopup;pop cut")
    axlShell(sprintf(nil "pick %f %f" xa ya ))
    axlShell(sprintf(nil "pick %f %f" xb yb ))
    axlShell("Done")
  • DE202408202727
    DE202408202727 over 7 years ago in reply to ENEGUE
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/5432.Eugene_5F00_cut.zip
    Using a mixture of shell and Skill commands isn't recommended. See attached.
  • ENEGUE
    ENEGUE over 7 years ago in reply to DE202408202727
    Wow, you come out with the skill command..Thanks! i definitely take sometimes to look at it and understand.
    Eugene
