  3. PAD on VIA.
  • Replies 12
  • Subscribers 19
  • Views 17140
PAD on VIA.
karthikeyan123
karthikeyan123 over 7 years ago
I am new to skill can you help me. I want to highlight the pad where the via in the pad. Can you share me the skill code
  • DE202408202727
    DE202408202727 over 7 years ago in reply to karthikeyan123 +1
    You may be better off using Constrain Management tools to do this.
  • karthikeyan123
    karthikeyan123 over 7 years ago in reply to luanvn81
    Thanks for your reply.
    Here i don't want the via outer layer overlap i want inter drill of via overlapped in the pad.
  • karthikeyan123
  • DE202408202727
  • luanvn81
    luanvn81 over 7 years ago in reply to karthikeyan123
    Hi!  i have fixed code, let try it again.
    axlCmdRegister( "VOP" `VOP)
    (defun VOP ()
    originalVisible = axlVisibleGet()
    designName = axlCurrentDesign()
    design_path = axlGetDrawingName()
    design_unit = car(axlDBGetDesignUnits())
    count_num = 0
    All_syms = list()
    ;#### Open temp files to work on ####
    writeOutFile = outfile("./Via_on_pad_report.log" "w")
    timeperform = fileTimeModified("Via_on_pad_report.log")
    fprintf(writeOutFile, "Design name: %s\n", design_path)
    fprintf(writeOutFile, "%s %s\n\n", "Check Date: ", timeToString(timeperform))
    fprintf(writeOutFile, "%s\n", "------------------------------------------------")
    fprintf(writeOutFile, "%-8s %-8s %-18s\n\n", "Symbol", "Layer", "Drc Location")
    foreach(sym, axlDBGetDesign()->symbols
    sym_refdes = sym->refdes
    Sym_side = if(sym->isMirrored, "BOTTOM", "TOP");end if
    Sym_pins = sym->pins
    axlVisibleDesign(nil)
    axlVisibleLayer(strcat("VIA CLASS/", Sym_side) t)
    axlSetFindFilter(?enabled '(NOALL VIAS) ?onButtons '(NOALL VIAS))
    axlClearSelSet()
    foreach(pin Sym_pins
    pin_pad = axlDBGetPad(pin, strcat("ETCH/", Sym_side), "REGULAR")
    pin_pad_bBox = pin_pad->bBox
    pin_bBox_chk = list(axlMXYAdd(pin->xy car(pin_pad_bBox)) axlMXYAdd(pin->xy lastelem(pin_pad_bBox)))
    data_in_box = axlGetSelSet(axlSingleSelectBox(pin_bBox_chk))
    axlClearSelSet()
    foreach(via data_in_box
    via_pad = axlDBGetPad(via, strcat("ETCH/", Sym_side), "REGULAR")
    size_via = abs(xCoord(car(via_pad->bBox))- xCoord(cadr(via_pad->bBox)))
    Via_pad_drillSize = via->definition->drillDiameter
    expand_value = abs(size_via - Via_pad_drillSize)*(-1.0)
    Via_poly = car(axlPolyFromDB(via ?padType 'REGULAR))
    ViaHole_poly = car(axlPolyExpand(Via_poly expand_value/2 'NONE))
    Pin_poly = car(axlPolyFromDB(pin ?padType 'REGULAR))
    AndPoly = car(axlPolyOperation(ViaHole_poly Pin_poly 'AND))
    if(AndPoly != nil then
    count_num = count_num + 1
    fprintf(writeOutFile, "%-8s %-8s %-L\n", sym_refdes, Sym_side, pin->xy)
    );end if
    );end foreach
    );end foreach
    );end foreach
    ; Close the file and wrap up
    fprintf(writeOutFile,"Total error found: %d errors\n", count_num)
    fprintf(writeOutFile, "%s\n", "END OF FILE")
    close(writeOutFile)
    axlVisibleSet(originalVisible)
    axlShell("redisplay")
    if(count_num > 0 then
    axlUIViewFileCreate("Via_on_pad_report.log", "Via_on_pad_report" nil )
    else
    axlUIConfirm("No error found.")
    if(isFile("Via_on_pad_report.log") == t then deleteFile("Universal_via_check.log"));end if
    ); end if
    );end defun VOP
    Luan
  • karthikeyan123
    karthikeyan123 over 7 years ago in reply to DE202408202727
    Thank you dave keep supporting  for my future doubts thank you again.
