  3. PAD on VIA.
  • Replies 12
  • Subscribers 19
  • Views 17139
PAD on VIA.
karthikeyan123
karthikeyan123 over 7 years ago
I am new to skill can you help me. I want to highlight the pad where the via in the pad. Can you share me the skill code
  • DE202408202727
    DE202408202727 over 7 years ago in reply to karthikeyan123 +1
    You may be better off using Constrain Management tools to do this.
  • DE202408202727
    Try the attached code. It's not very efficient but should give you an idea about where to start.
    defun( DE_viaInPinList ()
    let((vias, symSide, layer, pad, padPoly, viaInPinList, outPort)
    axlSetFindFilter(?enabled '("noall", "invisible", "vias"), ?onButtons '("noall", "vias"))
    axlAddSelectAll()
    vias = axlGetSelSet()
    foreach(sym, axlDBGetDesign() ->symbols
    foreach(pin, setof(pin, sym ->pins, !pin ->isThrough)
    symSide = if(sym ->isMirrored, "BOTTOM", "TOP")
    layer = strcat("ETCH/", symSide)
    pad = axlDBGetPad(pin, layer, "REGULAR")
    when(pad ->figure
    padPoly = car(axlPolyFromDB(pin, ?layer layer, ?padType 'REGULAR))
    when(padPoly && exists(via, vias, axlGeoPointInShape(via ->xy, padPoly) && memv(layer, via ->startEnd))
    viaInPinList = cons(list(symSide, pin ->xy), viaInPinList)
    if(viaInPinList then
    outPort = axlDMOpenFile("MISC", "ViaInPadReport.txt", "w")
    foreach(side, '("TOP", "BOTTOM")
    fprintf(outPort, "%s:\n", side)
    foreach(pin, setof(pin, viaInPinList, car(pin) == side)
    fprintf(outPort, "\t%L\n", cadr(pin))
    axlDMClose(outPort)
    axlUIViewFileCreate("ViaInPadReport.txt", "Via-in-Pad Report", nil, 20:30)
    else
    axlUIConfirm("No via-in-pad found")
  • karthikeyan123
    karthikeyan123 over 7 years ago in reply to DE202408202727
    Thank you so much dave.
  • karthikeyan123
    Hai dave
    It shows only fully filled vias in the pad but i need to show if it liitle bit touched in the pad  that also need to show.
  • karthikeyan123
  • luanvn81
    luanvn81 over 7 years ago in reply to karthikeyan123
    Hi, try this  code
    axlCmdRegister( "VOP" `VOP)
    (defun VOP ()
    axlShell("redisplay")
    originalVisible = axlVisibleGet()
    designName = axlCurrentDesign()
    design_path = axlGetDrawingName()
    design_unit = car(axlDBGetDesignUnits())
    err_count = 0
    All_syms = list()
    ;#### Open temp files to work on ####
    writeOutFile = outfile("./Via_on_pad_report.log" "w")
    timeperform = fileTimeModified("Via_on_pad_report.log")
    fprintf(writeOutFile, "Design name: %s\n", design_path)
    fprintf(writeOutFile, "%s %s\n\n", "Check Date: ", timeToString(timeperform))
    fprintf(writeOutFile, "%s\n", "------------------------------------------------")
    fprintf(writeOutFile, "%-8s %-8s %-18s\n\n", "Symbol", "Layer", "Drc Location")
    foreach(sym, axlDBGetDesign()->symbols
    sym_refdes = sym->refdes
    Sym_side = if(sym->isMirrored, "BOTTOM", "TOP");end if
    Sym_pins = sym->pins
    axlVisibleDesign(nil)
    ;axlVisibleLayer(strcat("PIN/", Sym_side t))
    axlVisibleLayer(strcat("VIA CLASS/", Sym_side) t)
    ;axlShell("redisplay")
    axlSetFindFilter(?enabled '(NOALL VIAS) ?onButtons '(NOALL VIAS))
    axlClearSelSet()
    foreach(pin Sym_pins
    pin_pad = axlDBGetPad(pin, strcat("ETCH/", Sym_side), "REGULAR")
    pin_pad_bBox = pin_pad->bBox
    pin_bBox_chk = list(axlMXYAdd(pin->xy car(pin_pad_bBox)) axlMXYAdd(pin->xy lastelem(pin_pad_bBox)))
    data_in_box = axlGetSelSet(axlSingleSelectBox(pin_bBox_chk))
    axlClearSelSet()
    foreach(via data_in_box
    Via_poly = car(axlPolyFromDB(via ?padType 'REGULAR))
    Pin_poly = car(axlPolyFromDB(pin ?padType 'REGULAR))
    AndPoly = car(axlPolyOperation(Via_poly Pin_poly 'AND))
    if(AndPoly != nil then
    err_count = err_count + 1
    fprintf(writeOutFile, "%-8s %-8s %-L\n", sym_refdes, Sym_side, pin->xy)
    );end if
    );end foreach
    );end foreach
    );end foreach
    ; Close the file and wrap up
    fprintf(writeOutFile,"Total error found: %d errors\n", err_count)
    fprintf(writeOutFile, "%s\n", "END OF FILE")
    close(writeOutFile)
    axlVisibleSet(originalVisible)
    if(err_count > 0 then
    axlUIViewFileCreate("Via_on_pad_report.log", "Via_on_pad_report" nil )
    else
    axlUIConfirm("No error found.")
    if(isFile("Via_on_pad_report.log") == t then deleteFile("Universal_via_check.log"));end if
    ); end if
    );end defun VOP
    Luan.
