  3. How can I use the skill code to save flash symbol or shape...
  • Subscribers 18
  • Views 11413
How can I use the skill code to save flash symbol or shape symbol?
Rosery
Rosery over 7 years ago
Hi all;
I have completed a skil file to create the flash symbol and shape symbol ,but I could not found a way to save them to disk.
Is there a way to save them?
  • DE202408202727
    DE202408202727 over 7 years ago
    axlSaveDesign
  • Rosery
    Rosery over 7 years ago in reply to DE202408202727
    thanks for your apply, and this function is essentially the Allegro "save" command.
    What i meant is that there is a skill program (run in design) can   create shape symbols and flash symbols ,but I can only use them  in current design .
    More ,What I  wanted is  that how to save flash symbols and shape symbols to disk.
  • DE202408202727
    DE202408202727 over 7 years ago in reply to Rosery
    This is relatively difficult to achieve. The best way is to create and run a script using Skill and run a separate session of allegro with the script file.
    Here's a function example that might help you:
    defun( AFn_createThermalFlash (name); eg. name = "th395od345id55g45"
    let((data, cwd, templateFile, fsm, p, scriptFileName, cmd)
    name = lowerCase(name)
    data = parseString(name, "th od id g")
    when(length(data) == 4
    data = mapcar('readstring data)
    cwd = getWorkingDir()
    templateFile = "[pathToTemplates]/blank_thermal_flash.dra"
    if(isFile(templateFile) then
    p = axlDMOpenFile("ALLEGRO_SCRIPT", "flash", "w")
    if(p then
    sprintf(fsm "%s/%s.fsm", cwd, name)
    when(isFile(fsm), axlOSFileMove(fsm, strcat(fsm, ".old")))
    scriptFileName = get_filename(p)
    fprintf(p, "setwindow pcb\n")
    fprintf(p, "generaledit\n")
    fprintf(p, "prmed\n")
    fprintf(p, "setwindow form.prmedit\n")
    fprintf(p, "FORM prmedit type Flash\n")
    fprintf(p, "FORM prmedit apply\n")
    fprintf(p, "FORM prmedit done\n")
    fprintf(p, "add flash\n")
    fprintf(p, "setwindow form.thermflash\n")
    fprintf(p, "FORM thermflash indiam %2.3f\n", cadr(data) / 100.0)
    fprintf(p, "FORM thermflash outdia %2.3f\n", car(data) / 100.0)
    fprintf(p, "FORM thermflash spkwdth %2.3f\n", caddr(data) / 100.0)
    fprintf(p, "FORM thermflash spknum 4\n")
    fprintf(p, "FORM thermflash spkangl %d\n", cadddr(data))
    fprintf(p, "FORM thermflash done\n")
    fprintf(p, "save_as \"%s\\%s.dra\"\n", cwd, name)
    fprintf(p, "create symbol\n")
    fprintf(p, "fillin \"%s\\%s.fsm\"\n", cwd, name)
    fprintf(p, "exit\n")
    fprintf(p, "fillin no\n")
    drain(p)
    axlDMClose(p)
    sprintf(cmd, "allegro -s flash.scr -p %s %s", cwd, templateFile)
    shell(cmd)
    deleteFile(scriptFileName)
    axlUIConfirm(lsprintf("Local flash symbol created: %s", fsm))
    else
    axlUIConfirm("Error: Could not create flash script file", 'error)
    else
    axlUIConfirm(lsprintf("Error: Could not create flash template: %s", templateFile), 'error)
  • Rosery
    thanks a lot
    I'll try
