  3. Need your help on Highlight the error location in report...
  • Subscribers 19
  • Views 11356
Ragavan T
Ragavan T over 7 years ago
Dear All,
I am a CAD Librarian, wishes to learn skill programming to check the footprint parameters, like line width and package height, and design unit. for the first attempt, I started to code for checking line width of assembly outline, and also need to report an error in case of line width not as per standard. code inserted below, To enhance this code if in case of a width not as per standard it supposed to report error location.
axlCmdRegister("assycheck" 'asscheck)
defun( asscheck ()
let((allLines, ends)
l_tmp = axlDBGetDesignUnits()
unit = nth(0 l_tmp)
;printf("Units are in %L\n", unit)
axlVisibleDesign(nil)
axlVisibleLayer("PACKAGE GEOMETRY/ASSEMBLY_TOP" t)
axlSetFindFilter(?enabled list("noall" "Lines") ?onButtons list("noall" "Lines"))
allLines = axlGetSelSet(axlAddSelectAll())
axlClearSelSet()
i_tmp = list()
p = axlDMOpenLog("REPORT")
    foreach(line, allLines
        foreach(segment, line ->segments
            ends = segment ->width
            if(unit == "millimeters" && ends != 0.0254 then
                i_tmp = cons(end i_tmp)
            if(unit == "mils" && ends != 1.00 then
        );end foreach segment
    );end foreach line
        if(length(i_tmp) == 0 then
            fprintf(p, "Units are in %L\n\n", unit)
            fprintf(p, "ASSEMBLY LINE WIDTH IS OK\n", end)
        if(length(i_tmp) > 0 then
            ;printf("ERRORS\n", end)
            fprintf(p, "ERROR:ALL ASSEMBLY LINE WIDTH ARE NOT AS PER STANDARD.\n\n", end)
    axlDMClose(p)
    axlUIViewFileCreate("REPORT.log" sprintf(nil, "REPORT", end), nil)
);end let
axlVisibleDesign(t)
axlMsgPut("Checking completed.See Report.")
);end defun
Thanks in advance
Ragavan Thangaraj
CAD Libararian
  • Jason Hsu
    Jason Hsu over 7 years ago +1
    Hi Ragavan, You can use axlHighLightObject(obj), axlZoomToDbid(obj t) to highlight the line that width doesn't equal 0.0254 or 1. After use axlUIConfirm(), dehighlight the object to use axlDehighlightObject…
  • Jason Hsu
    Hi Ragavan,
      You can use axlHighLightObject(obj), axlZoomToDbid(obj t) to highlight the line that width doesn't equal 0.0254 or 1. After use axlUIConfirm(), dehighlight the object to use axlDehighlightObject(obj). It will be more clear on allegro window than log file. I think : )
  • Ragavan T
    Ragavan T over 7 years ago in reply to Jason Hsu
    Hi Jason Hsu,
    Thanks for your time to reply, lets me try this.
  • RagavanT
    RagavanT over 7 years ago in reply to Jason Hsu
    I tried and failed to get the exact output, and don't know how to use it. as a new to skill to skill programming.
  • Jason Hsu
    Jason Hsu over 7 years ago in reply to RagavanT
    Just a sample.
        when( car(axlDBGetDesignUnits()) == "millimeters"   line_width = 0.1524 )
        when( car(axlDBGetDesignUnits()) == "mils"          line_width = 6.0)
        axlClearSelSet()
        axlVisibleLayer("Package Geometry/Silkscreen_Top" t )
        axlVisibleUpdate(nil)
        axlSetFindFilter(?enabled list( "noall" "lines") ?onButtons list( "noall" "lines))
        axlAddSelectAll()
        allLine = axlGetSelSet()
        foreach( line allLine
            foreach( segment line->segments
                 width = segment ->width
                 if( width == line_width then
                     fprintf(AMC_LOG "PASSED: The line width is %L on\"Package Geometry/Silkscreen_Top\".\n" width)
                 else
                      startEnd = car(line ->segments)->startEnd
                      axlHighlightObject(segment)
                      axlZoomToDbid(segment t)
                      axlUIConfirm(sprintf(nil "The line width is %L on \"Package Geometry/Silkscreen_Top\", should be %L\n" width line_width))
                      axlDehighlightObject(segment)
                      fprintf(AMC_LOG "FAILED: The line width is %L on \"Package Geometry/Silkscreen_Top\" at %L, should be %L\n" width startEnd line_width)
                      results->errors = results->errors + 1
