  3. how can load the Dll files and use it?
  • Subscribers 20
  • Views 13645
Roser
Roser over 7 years ago
Hi all
I had tried to use dll files ,but I can only load dll file is the example file named "axlecho_plugin.dll", and the others dll files I  created can't be load ,
this is the codes:
dll_name="dllcreate"
testDll=axlDllOpen(dll_name)
when run over this function ,awlayw return nil except dll_name="axlecho_plugin".
but all Dll files are the same path.and No waring and Error when create the dll files.
what wrong with it ? and how can i do to void this issue, thanks !
  • DE202408202727
    DE202408202727 over 7 years ago
    Here is a function I have used in the past:
    defun( DE_pluginsLoad (pluginName, pluginSymsList)
    prog((dllLib, symName); pluginName
    dllLib = axlDllOpen(pluginName); load dll library
    if(dllLib then
    foreach(symList, pluginSymsList
    symName = cadr(symList)
    set(car(symList), axlDllSym(dllLib, symName))
    unless(eval(car(symList)), axlMsgPut(list(lsprintf("'%s' symbol not present in %s Dll", symName, pluginName), 2)), axlDllClose(dllLib), return())
    else printf("Can't find %s Dll\n" pluginName), return()
    return(dllLib)
  • Roser
    Roser over 7 years ago in reply to DE202408202727
    Hi Dave, the function called  axlDllOpen  ,it's return value already correct,
    but how can i pass the parameters to dll's function?
    the C++ code for test is below:
    int numberAdd(&a,&b)
    {return a+b;
    The skill code is below:
    defun( testdll()
    dll_name="mydll"
    dll_lib=axlDllOpen(dll_name)
    if(dll_lib then
    printf("Opening %s.dll\n" dll_Name)
    dll_Add = axlDllSym(dll_lib "Add")
    printf("\nExample of axlDllCall with 1 of each argument\n")
    ret = axlDllCall(dll_Add 3 4)
    printf("Return  %L\n" ret)
    else
    printf("Can't find %s.dll\n" dll_Name)
    is this Codes right? could you give me any advice?Thk
  • DE202408202727
    DE202408202727 over 7 years ago in reply to Roser
    Sorry. I have't used this for years.
  • koffeekingston
    koffeekingston over 7 years ago in reply to Roser
    If you are unable to do so then you need to install some plugin so that there won't be DLL error, so far dell printer error 016-302 helped me to get the solution of this.
  • Hoangkhoipcb
    Hoangkhoipcb over 2 years ago
    Hi Roser!
    You can refer in this shown.
    HoangKhoi.
