  3. How to copy a file using SKILL?
  • Subscribers 18
  • Views 14603
EvanShultz
EvanShultz over 7 years ago
This is probably a basic question, but for some reason I'm not finding an answer by playing around with code, reading the docs, or Googling. Surely my fault.
How can I copy a file from one location to another? In my case, I want to snag a file from $CDS_SITE that is used for configuration and bring it local.
Not finding a direct SKILL function my belief was I could call to the host OS for a file copy but I don't see that function either. I do not want to simply read the file contents and produce a copy that way, which I can do.
Thanks!
  • DE202408202727
    DE202408202727 over 7 years ago
    Try axlOSfileCopy (from memory)
  • DE202408202727
    Try axlOsfileCopy (from memory)
  • EvanShultz
    EvanShultz over 7 years ago in reply to DE202408202727
    Yep. That is it. Thank you! I was sure I had seen it at one point but couldn't find it. (And I was mostly looking at the vase SKILL and not Allegro SKILL functions.)
    Another question: can you, or anyone else, give me a working example of this file? The function is returning 'nil' and I'm not sure what I'm doing wrong. I first tried:
    axlOSFileCopy(axlOSSlash(strcat(axlGetVariable("CDS_SITE") "\\pcb\\<file name>.<file extension>")) axlGetVariable("cwd") nil)
    axlGetVariable("cwd") seems to work and gives a fully validated path starting with a drive letter and using single forward slashes. This is the same format I see when I run "set" at the command prompt. Interestingly, axlGetVariable("cdsroot") gives me a drive letter and double backslashes.
    I've tried many variations of the first argument but the function is always returning 'nil' for me. I tried using a drive letter vs UNC path, forward- and backward-slashes, single- and double-slashes...
    I then tried copying between local directories but I still always get 'nil' with no file copied and I tried the same permutations mentioned above. The issue must be me. Ideally I would like to copy from a UNC network path to a local drive on Windows, if that matters. I'm running 17.2 S051. Any tips?
  • DavidJHutchins
    DavidJHutchins over 7 years ago in reply to EvanShultz
    Below is an example from some code I wrote years ago:
    (FileList = list("art_aper.txt" "art_param.txt"))
    foreach(filename FileList
    if( Version < 14.0 then
    if((axlVersion 'isWindows) then
    system(strcat("copy " filename " art"))
    when(PasteList
    system(strcat("copy " filename " outputs"))
    else
    system(strcat("cp " filename " art"))
    when(PasteList
    system(strcat("cp " filename " outputs"))
    else
    (SrcName = strcat(simplifyFilename(".") "/" filename))
    (DestName = strcat(simplifyFilename(".") "/art/" filename))
    unless(axlOSFileCopy(SrcName DestName nil) axlUIConfirm("file copy FAILED"))
    Below is an allegro session implementing your copy example:
    Opening existing design...
    Command > skill axlGetVariable("CDS_SITE")
    "D:/Cadence/SPB_16.6/share/local"
    Command > skill axlGetVariable("cwd")
    "D:/SPB_Data/xxxxx/yyyyyy"
    Command > skill
    Skill > setq file_name "README"
    "README"
    Skill > setq file_ext "txt"
    "txt"
    Skill > setq SrcFile sprintf(nil "%s/pcb/%s.%s" axlGetVariable("CDS_SITE") file_name file_ext)
    "D:/Cadence/SPB_16.6/share/local/pcb/README.txt"
    Skill > setq DestFile sprintf(nil "%s/%s.%s" axlGetVariable("cwd") file_name file_ext)
    "D:/SPB_Data/xxxxx/yyyyyy/README.txt"
    Skill > axlOSFileCopy(SrcFile DestFile nil)
    t
    Skill >
  • EvanShultz
    EvanShultz over 7 years ago in reply to DavidJHutchins
    Ugh. I'm daft. Yes, that works. Thank you!
    For the destination I wasn't giving a file name, only the path. The function example isn't super clear since it doesn't give file extensions, but it was a silly mistake on my part now that I see the problem clearly. (It would be a nice enhancement for the function to retain the source file name if only a folder is given as a destination.)
