  3. Mirroring top to buttom
  • Subscribers 18
  • Views 10287
karthikeyan123
karthikeyan123 over 7 years ago
hai,
I would like to mirror top to bottom i attached   the code but that code mirrored left to right any one please recorrect the code send me please i am new to skill
axlCmdRegister("mirror_box" 'mirror_box ?cmdType "interactive")
symDBID = nil
procedure(mirror_box()
let( (symDBID UC_mbMark UC_mbPopup notdone)
axlSetFindFilter(?enabled '("NOALL" "SYMBOLS" "VIAS" "CLINES" "LINES" "SHAPES" "TEXT")
                       ?onButtons '("SYMBOLS" "VIAS" "CLINES" "LINES" "SHAPES" "TEXT"))
;; Set the Control Panel to the Find tab
axlControlRaise('find)
    UC_mbMark = axlDBTransactionStart()
UC_mbPopup = axlUIPopupDefine( nil (list
     (list "Oops" 'UC_mbOops)
    (list "Mirror" 'UC_mbMirror)
        (list "Done" 'UC_mbDone)
      (list "Cancel" 'UC_mbCancel)
    axlUIPopupSet(UC_mbPopup)
    notdone = t
    while(notdone
          symDBID = axlGetSelSet(axlSelect(?prompt "Select objects to mirror"))
        axlDBTransactionMark(UC_mbMark)
          if(symDBID then
            axlTransformObject(symDBID, ?mirror t)
          ); endif
    ); end while
)); let and procedure
procedure(UC_mbMirror()
    axlClearSelSet()
);end procedure
procedure(UC_mbOops()
    axlDBTransactionOops(UC_mbMark)
    axlClearSelSet()
); end procedure
procedure(UC_mbCancel()
      axlUIWPrint(nil "** All changes Cancelled ! **")
      axlDBTransactionRollback(UC_mbMark)
      notdone = nil
      axlClearSelSet()
      axlCancelEnterFun()
    axlUIPopupSet( nil)
); end procedure
procedure(UC_mbDone()
     axlUIWPrint(nil "Done")
     axlDBTransactionCommit(UC_mbMark)
     notdone = nil
      axlClearSelSet()
     axlFinishEnterFun()
    axlUIPopupSet( nil)
); end procedure
  • DE202408202727
    DE202408202727 over 7 years ago
    This is not an easy task. As a beginner in Skill I suggest you try something easier.
    However, the code you need could be based on this:
    flipInY = t; or nil if you prefer
    loc = [pick a point]
    objs = axlGetSelSet(axlSelect(?prompt "Select objects to mirror"))
    mirroredObjs = axlTransformObject(objs, ?mirror t, ?angle when(flipInY, 180.0), ?origin loc)
  • karthikeyan123
    karthikeyan123 over 7 years ago in reply to DE202408202727
    Thanks for your reply dave,
    Sure dave i will choose easier task but for this case i want i don't know how to elaborate this can you share me the full skill code please.
