  3. Error when remove voids from dynamic shape
  • Subscribers 18
  • Views 10177
shuchen2
shuchen2 over 7 years ago
I am trying to remove some voids on dynamic filled shapes when some criteria is met. I have try two approaches:
1. extract the polygons from the voids and build shapes from these polygons (expand a little bit for overlap). Then merge these shapes. But this is slow.
2. I would like to use the axlDBOpenShape, axlShapeDeleteVoids, and axlDBCloseShape to delete these voids. But I get the warning below.
*WARNING* (axlShapeDeleteVoids): Cannot delete voids in an auto-generated shape
Then I trie to axlDBOpenShape(i_shape->shapeBoundary) to open the boundary shape instead, then the operation would delete the whole shape.
Any ideas? Thanks!!!!!
  • shuchen2
    Updates:
    Solved. I just found out the dbid is removed after the shape is opened. And the voids' dbids are also removed.
    Then I cannot close the original shape dbid, and cannot delete the original voids' dbids. Operations should be set after the shape is opened.
