  3. Dangling line report
  • Subscribers 18
  • Views 11612
karthikeyan123
karthikeyan123 over 7 years ago
Hai,
I want to take dangling line report layer wise is there is any way to take layer wise dangling line report. Where in the quick report it shows whole. if any body knows how to get layer wise dangling line report using skill or any other ways please guide me. or share me the skill code i am new to skill.
Regards
KARTHI
  • DE202408202727
    DE202408202727 over 7 years ago
    Make a system call to the report batch utility.
    report <-v ...> <brd> [out]
    I think the report you need is "sum"
  • karthikeyan123
    karthikeyan123 over 7 years ago in reply to DE202408202727
    Hai dave,
    Thanks for your reply dave i don't know how to do this Actually The dangling lines need to display layer wise. Here in the quick report displays whole dangling lines it collapsed that i want to layer wise sorted order. This is easy way to do by layer wise.
    For ex:
    << Dangling Lines >>  - Location marked with a star (*) is dangling.
      Net                 Layer                  Length       Location
      N23101595            TOP                    63.12     *(285.10 6542.80) to  (285.10 6479.68)
      XCVR_1C_REFCLK_P     TOP                    96.45     *(1709.13 3300.03) to  (1709.94 3396.14)
      XCVR_1C_REFCLK_P     03_SIG1              1209.73     *(366.10 3320.00) to  (-607.00 3402.51)
      N23037512            BOTTOM                 70.13     *(115.10 8545.00) to  (185.10 8544.68)
      N23037487            03_SIG1              3935.64     *(115.10 8445.00) to  (666.51 5158.59)
      N23037467            BOTTOM                 65.13     *(115.10 8345.00) to  (180.10 8344.68)
      N23041381            TOP                    43.24      (336.00 8345.00) to *(375.10 8355.00)
      N23041477            TOP                    89.10      (556.00 8445.00) to *(645.10 8445.00)
      N23041477            TOP                   133.98     *(650.10 8350.00) to  (556.00 8445.00)
      FMC_XFP0_MOD_DESEL   03_SIG1              1128.81     *(520.10 4215.00) to  (-457.00 4102.51)
      FMC_XFP0_TX_DIS      03_SIG1              1153.07     *(525.10 4285.00) to  (-457.00 4202.51)
      FMC_XFP0_INTR_B      03_SIG1              1198.39     *(525.10 4250.00) to  (-507.00 4152.51)
    Here the layer get collapsed i want that in sorted order layer wise. Help me clearly dave how to do this please.
  • DE202408202727
    DE202408202727 over 7 years ago in reply to karthikeyan123
    I hope you can understand this code:
    defun( DE_sortDanglingReport (reportName)
    let((outReportName, inPort, outPort, ln, subclass, layerNo, data)
    outReportName = strcat(cadr(axlDMFileParts(reportName)), "_sorted.", cadddr(axlDMFileParts(reportName)))
    inPort = axlDMOpenFile("MISC", reportName, "r")
    outPort = axlDMOpenFile("MISC", outReportName, "w")
    gets(ln, inPort), fprintf(outPort, ln); Header line 1
    gets(ln, inPort), fprintf(outPort, ln); Header line 2
    gets(ln, inPort), fprintf(outPort, ln); Header line 3
    while(gets(ln, inPort); Read the data lines
    subclass = cadr(parseString(ln))
    layerNo = axlLayerGet(strcat("ETCH/", subclass)) ->number
    data = cons(list(layerNo, ln), data)
    axlDMClose(inPort)
    foreach(item, mapcar('cadr, sortcar(data, 'lessp))
    fprintf(outPort, item)
    axlDMClose(outPort)
    axlUIViewFileCreate(outReportName, outReportName, nil)
  • karthikeyan123
    Hai dave,
    It comes E- *Error* DE_sortDanglingReport: too few arguments (1 expected, 0 given) - nil
    While adding in the menu bar it worked But its shows as like the quick reports There is no sorted order in dangling line.
  • DE202408202727
    I suggest that you learn more about Skill language programming before you continue. Understanding parsing values to a function is very basic coding.
