  3. Command not found when calling a skill function from a ...
  • Subscribers 18
  • Views 11613
Command not found when calling a skill function from a menu
ttkka
ttkka over 7 years ago
I can run a skill function from the command line but not from a menu.
Running from the menu, I get "command not found: skill_function"
Do I need to do something else so that this function can be seen?
the .il file is placed in the %CDS_SITE%\PCB\skill folder and I have axlCmdRegister("skill function" 'skill_function)
  • DE202408202727
    DE202408202727 over 7 years ago
    You need to load it first. You can do this by including an autoload command in your allegro.ilinit file.
    eg skill_function.autolad = "mySkillFile.il"
  • ttkka
    ttkka over 7 years ago in reply to DE202408202727
    So skill files in the skill directory aren't loaded automatically on start-up?
    Is there a way to do this automatically or is this not recommended?
  • DE202408202727
    DE202408202727 over 7 years ago in reply to ttkka
    That's right. The correct method is to use your allegro.ilinit to load the files you need. You could easily include a function in there to load all the skill files present.
